Furnace replacement - Fiberglass RV
Old 09-06-2016, 09:04 PM   #1
drdog's Avatar
Trailer: Boler 13'
Yukon
Furnace replacement
Finally gave up on the original gravity furnace and put an Atwood 18,000 btu furnace in. Great addition but sure draws the 12 volt solar system down so having to add more power there.
But I've torn out the old one and before I retire it to landfill, is it of any use to anyone out there. Pretty gnarly but parts may be useful to someone. Let me know and if no response in a couple weeks, out it goes. From a 1973 b1300.
drdog is offline   Reply With Quote
Old 09-07-2016, 08:12 AM   #2
Can you post a picture.. I have a Trillium that the previous owner removed and I'm looking for one to put back in it.. Don't know if the Boler was anything like the Trillium but it want hurt to look at it...
Old 09-07-2016, 02:33 PM   #3
drdog's Avatar
Trailer: Boler 13'
Yukon
Furnace
I'll take a picture later today. It's a WagonMaster and in pretty rough shape. Gravity and no air movement (problem #1) and I'm not sure the thermostat ever put out more than the pilot. Never have been able to find info or manual on a WagonMaster and people mostly laughed when I mentioned it.
The one I put in was 2" too long. We moved the water lines (and replaced and re-routed the line) and then put a 1" wood 'trim' out from the front. Fits fine now. Went for the 18,000 btu since the smaller one was the same price. I think Panther RV is having a sale now. I'll get a picture of that too. A bit noisy but very toasty. Depends on how cold you plan to camp...
Old 09-08-2016, 02:56 PM   #4
David Tilston's Avatar
Randy, I don't think a wagon master will be of any use to you.
Old 09-26-2016, 10:00 AM   #5
Trailer: 1973 13' Trillium
furnace replacement and relocation
Hi David! How are u today? Wondering if you could suggest a replacement furnace for our 1973 Trillium 1300? Also-could the new furnace be moved to the space below the tall closet and if yes, what would be the process? Thanks for any help! You can e-mail me via abandc2@shaw.ca if that works better for you.
jagbor is offline   Reply With Quote
Old 09-26-2016, 11:53 AM   #6
drdog's Avatar
Trailer: Boler 13'
Yukon
Replacement Furnace
Take a look at the Atwood from Panther RV. Small and will fit almost anywhere. 12k btu and 18k btu and both the same price. I've been using one to replace the old WagonMaster that came with the boler. Works really well.
Old 09-26-2016, 02:44 PM   #7
Sorry, but the 1300's have the furnace in the kitchen because it did not fit under the closet. That is where the wheel well is.
Trillium did put a forced air furnace there in the 80's, but they shortened the closet to do it. Also, it stuck out. It looked kinda funny. Some say it looked pregnant. Another place they put a forced air furnace was in the dinette seat.
Old 09-26-2016, 04:12 PM   #8
Do you have any idea how it would compare to a ProPex furnace?
Old 09-26-2016, 04:23 PM   #9
furnace replacement
Thanks for the info. What is the fix for preventing a sleeping bag from catching fire if the furnace goes back under the sink? Is there some metal grate or ? that can be purchased or does a 12000-16000 btu unit just not get that hot to work about the potential fire hazard? This is all new to me so please excuse my ignorance.
Old 09-26-2016, 05:07 PM   #10
Not ignorance. Surface temperature is the reason that gravity furnaces lost their CSA / UL approval. I assume that there were fires. But I have not read any actual accounts. I bet there were some melted sleeping bags though.
You could try a metal grate.
Old 09-26-2016, 06:11 PM   #11
Clayton's Avatar
Trailer: 1975 Trillium
http://www.fiberglassrv.com/forums/s...ad.php?t=75442
I installed a Propex heater this summer. Best mod I have done to my Trillium since I have owned it.
Clayton is offline   Reply With Quote
Old 09-26-2016, 09:17 PM   #12
drdog's Avatar
Trailer: Boler 13'
Yukon
Furnaces
Not familiar with the ProPlex, but the Atwood is going just fine. I can imagine that the gravity fed might be hot and cause problems, but with the forced air I've never had it get hot enough to cause a problem. The previous owner used to put plywood between furnace and bed, but I've never had it get that hot with the forced air.
boler, furnace
Boler Furnace Replacement Arlyn R Problem Solving | Owners Helping Owners 13 11-15-2020 01:18 PM
Furnace replacement for a 1977 Trillium 4500 billkateposs Problem Solving | Owners Helping Owners 21 09-09-2016 10:49 PM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
Replacement furnace for '72 13' boler? KevC Modifications, Alterations and Updates 6 11-18-2011 09:44 PM
Replacement Furnace - What Type Fits Michelle A Care and Feeding of Molded Fiberglass Trailers 3 04-25-2010 09:25 PM
