1974 Amerigo window problem - Fiberglass RV
Old 01-24-2016, 01:31 PM   #1
Trailer: amerigo & apache
Wisconsin
I purchased a 1974 amerigo FG-16. All the window pushouts are gone, so I have no idea what they look like. I'd like to make some. Can anybody get me a drawing with measurements and a pic of them. I have no idea what they look like or their length, width, etc. Thanks
donjdart is offline   Reply With Quote
Old 01-26-2016, 07:32 PM   #2
SteveV's Avatar
Trailer: Amerigo FG-16
Here are a couple of pics, hopefully they help some.
Also check this thread where I posted my repair for some of my missing latches. http://www.fiberglassrv.com/forums/f...ows-72039.html
Unfortunately the latches are a weak point on these windows. I had priced modern replacement windows for my Amerigo but @ $500.00+ each I figured I could live with these.
BTW the pics are of 2 windows that are out of their frames sitting side by side while renovations are underway.
SteveV is offline   Reply With Quote
Old 01-27-2016, 04:31 PM   #3
Wisconsin
Thanks, Now if the snow would melt and get warm out- I can start on it!
Old 01-30-2016, 08:18 AM   #4
Wisconsin
Is this the window part
It says this company purchase the remaining stock of Creation Inc. Is the 9 1/2 inch part in the middle of the page the Amerigo push out hardware?
Creation window parts
Old 01-30-2016, 08:49 AM   #5
SteveV's Avatar
It looks similar but where it attaches to the window frame is different.
Is there anything left of your latches? The straight arms are pretty easy to make, it's the part that is attached to the frame that's tougher to make & secure.
Old 01-30-2016, 09:36 AM   #6
Wisconsin
Nope all the hardware is gone. Can't find a single part from it in the camper.
Old 01-30-2016, 04:07 PM   #7
SteveV's Avatar
Here's some other shots to give you a better idea of how the latch operates.
The 8" lever attaches & pivots on the bracket that is connected to the window pane. When closed the lever will latch into a hook that's connected to the inside window frame.
Old 01-30-2016, 04:16 PM   #8
SteveV's Avatar
Here's a few shots from the outside. The short bracket (pivot point) that is attached to the pane was originally riveted in place. To re-rivet it properly you would need to split the pane where the two halves are riveted together and doing that gets you into a different set of issues like finding a suitable replacement spline for the plexiglass. I used JB weld to attach the ones I replaced.
Old 01-30-2016, 07:32 PM   #9
Wisconsin
thanks
Thanks for the info and pics. I start back at work Monday and it looks like we will be BURIED in snow Tues & Wed. But now I have the info to get at it in the Spring! Its about 5 " to tall to get in my garage! Thanks again!
amerigo
Canada - Amerigo - 1974 - $800 David Tilston Referrals: Molded Fiberglass Trailers 3 06-01-2012 03:03 PM
VA | 1974 Amerigo FG-16 01bogie Classified Archives 9 01-26-2012 07:24 AM
1974 Amerigo F16 (Good Shape) Madison, WI skirner Classified Archives 6 01-02-2010 01:45 PM
1974 18' Amerigo ... MUST GO, $1200 OBO Clancy Meyerhoeffer Classified Archives 12 11-21-2007 04:47 PM
