My 72 Boler Reno - Fiberglass RV
Old 05-15-2012, 01:31 PM   #1
slots881's Avatar
Trailer: 1972 Boler
My 72 Boler Reno
slots881 is offline   Reply With Quote
Old 05-15-2012, 01:34 PM   #2
slots881's Avatar
Trailer: 1972 Boler
Old 05-15-2012, 01:44 PM   #3
slots881's Avatar
Trailer: 1972 Boler
I Picked up this 72 Boler at the end of last fall. It sat all winter and I waited for the snow to stop so I could start working on it.
The trailer came pretty tidy on the inside with the walls being scrubbed and all the wiring and propane lines pulled.
Things I've done since I've had it:
-Replace the flooring with Wood Laminate.
-Did all the trailer wiring, along with adding the marker lights, and adding LED tail lights.
-Redid the 110v wiring. Added 3 outlets, 2 on the counter and 1 inside the cabinet by the fridge insert. The wiring was done to a breaker box with 2 15amp breakers.
-Cut some shelves for the cabinet.
-Redid the countertop with one I found at Ikea. It had to be cut to size. I just used a Circular saw with a 120tooth blade. I cut the holes for the sink and stove with a jig saw.
-I decided to paint the outside with Interlux Brightside paint. First I've primed it with Interlux Primer. I've decided to do White and Sea Green. The painting is a little hard as the PO decided to coat the front and back with truck bed liner. This adds a bumpy texture, I've sanded as much as I've wanted to to flatten it out.
I'll post some pictures of the finished paint in a bit
Old 05-15-2012, 01:54 PM   #4
slots881's Avatar
Trailer: 1972 Boler
I found a Waeco 12V fridge on Kijiji, so it'll make it's way into the Boler. I just have to figure out how I want to run the 12V system...
The inside was painted by my girlfriend. A cream colour to go with the cushion material she has picked out. We have ordered new foam and she'll be making new cushions.
Old 05-15-2012, 02:02 PM   #5
slots881's Avatar
Trailer: 1972 Boler
This is after 3 coats of Interlux Brightside paint. I've sanded and then wet sanded before the final coat. Up close, it's not a professional job, but for the price I paid(probably >250 for paint and supplies), it's pretty nice.
Old 05-15-2012, 06:30 PM   #6
Looks nice to me too Darragh
What's the purpose of the diamond plate on the back?
Thanks for posting the update pictures, it'll be great to see the finished product
Old 05-15-2012, 06:36 PM   #7
slots881's Avatar
Trailer: 1972 Boler
To tell you the truth, I got it from the PO with the Diamond plate on the back.. I haven't really looked into why it was placed there. There is no damage to the inside rear of the trailer. It could be that the frame was replaced and raised in 2002. Maybe that has something to do with it?
Old 05-15-2012, 06:41 PM   #8
I'm a fan of diamond plate, so I was just curious. If it's really shiny it may keep someone from following you too closely when under tow in the dark
Old 05-16-2012, 06:42 PM   #9
slots881's Avatar
Trailer: 1972 Boler
Installed the city water faucet today. Looks pretty shiny!
Old 05-16-2012, 06:47 PM   #10
D Davis's Avatar
Virginia
WOW, Beautiful job! Lots of hard work. Enjoy your camper and thanks for sharing the pics!
Old 05-16-2012, 08:09 PM   #11
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
Your paint job looks great! Good color choice. Look forward. to interior pics w/ the new cushions
Reid Larsen is offline   Reply With Quote
Old 05-17-2012, 05:44 AM   #12
Ian G.'s Avatar
Looks good
Great to see another Alberta Boler, we need to organize an event in southern Alberta.
Old 05-21-2012, 08:15 PM   #13
Trailer: Boler 1300
How did you apply the paint? In the pictures it has a real nice shine. Looks great.
dann is offline   Reply With Quote
Old 05-21-2012, 10:28 PM   #14
slots881's Avatar
Trailer: 1972 Boler
I used the roll and tip method. I first rolled on 3 coats of Interlux primer with sanding in between coats. I then rolled and tipped 3 coats of the Brightside with sanding in between the last 2 coats. I did a 4th coat on the Green but didn't notice that much of a difference.
I'm just waiting a few more days before applying any wax.
Old 05-25-2012, 04:33 PM   #15
Trailer: 13 Trillium
Looks wonderful! What did you do for the seams on the inside before you painted? It just looks so clean and finished! Can't wait to see the next pictures!
lhanna is offline   Reply With Quote
Old 05-25-2012, 05:57 PM   #16
slots881's Avatar
Trailer: 1972 Boler
Unfortunately, I don't know how the seams were done on the inside. They were done by the PO. I think it's just some "foam" like tape that they put over the seams.
Update, we've picked up the foam, and my girlfriend is sewing up the cushions. I've got everything to hook up the city water and have the propane tanks and holder on the front of the trailer.
I've also picked up an Iota dls45 with integrated charger, but I haven't installed it yet.
Old 05-25-2012, 06:17 PM   #17
Darragh, if I may... wait to apply wax. Fresh paint jobs need to really outgas. You'll know when it's done when you put your nose right up to the paint and breathe in. If it smells like 'paint' it's not ready for wax (hotrod... expensive paint background here....)
Old 05-25-2012, 06:48 PM   #18
slots881's Avatar
Trailer: 1972 Boler
Thanks Donna! That is something I did know about paint. What I haven't decided yet, is which kind of wax to use. Any tips?
Old 05-25-2012, 06:57 PM   #19
slots881's Avatar
Trailer: 1972 Boler
Here is just a little upgrade that my girlfriend added. The Backsplash! She picked out the colors which I guess tie into the cushion color..
Old 05-25-2012, 07:11 PM   #20
bec
Trailer: Escape 15 A
This Boler looks great .... nice job !!
bec is offline   Reply With Quote
1972, boler, brightside, renovation
76 Boler Reno/Rework kgingeri Modifications, Alterations and Updates 102 11-23-2021 06:05 PM
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
1972 boler Reno slots881 General Chat 1 05-05-2012 12:02 PM
Boler Reno Don A Modifications, Alterations and Updates 1 03-25-2011 09:40 AM
Boler Reno pics David Konduc Modifications, Alterations and Updates 1 08-20-2009 05:57 PM
