[quote]It is a great low budget option for a nice paint job. In some of the forums they went from 20 to 50 percent mineral spirits. I went with 10 percent mineral spirits added to a gloss white. After 2 coats I gave it a quick wet sand with some 400 grit paper. I put on 2 more coats and then said maybe someday Ill sand it out with 1000. On the bottom I used a rocker guard spray to give it some texture and the used a mix of flat and semi gloss black also with 10 percent mineral spirits. My garage was on the cool side so it took a little longer to dry. Now I'm going to finish the upholstry. Watched a few you tube videos on upholstry and almost half done that part
Attachment 27334
Hey Roy that looks good!! I am getting ready to try my hunter with this method. I read the thread the Charger guy did,looks Great!I am in the process of sanding down some of the old paint that was brushed on and it has a lot of brush marks. Mainly I am taking it down smooth and not always taking all of the old paint off. How much paint did it take to do yours? Did you use the small high density foam rollers? Thanks Harold
