Is this a pooched axle? - Fiberglass RV
Old 08-18-2014, 08:07 PM   #1
Banff, Alberta
Hi guys, related to my previous "thumpthumpthump" post
Managed to get both tires off the ground and both removed, however in doing so I see that the axle/tires doesn't really fall at all. Maybe and inch or two.
I'll attach a picture in a second. Shouldn't the arm be pointing more down than up??
THoughts/insight much appreciated.
Steve
And yes, I'm aware of how frightfully dangerous that jack-up is...
nelsons is offline   Reply With Quote
Old 08-18-2014, 08:19 PM   #2
Roy in TO's Avatar
It looks a little pooched.
See the diamond shaped weld on the left hand side of the torsion arm in your picture?
At rest the sides should be at about 45° to your axle tube. Or the top and bottom corners should be relatively plumb with the corners on the side being relatively level.
Old 08-18-2014, 09:33 PM   #3
Trailer: 2010 Scamp 16
I think Roy is correct. That arm would have originally been positioned so the square shaft made a <> diamond with the vertical points parallel with the frame. The point going toward the wheel does look sort of pointed up now by a fair amount and that is without load.
Think a new axle would probably be in order. Can't imagine having to do the jack stands you have in the picture on the side of the road to change a tire.
Old 08-19-2014, 07:42 AM   #4
Bob Miller's Avatar
Trailer: Class A Motorhome
Maybe one of the Boler peeps can tell us what the normal trailing arm angle should be.. Up, down or level? If it only moved 2" when unloaded, I suspect that it should be a lot lower than it is.
Old 08-19-2014, 08:56 AM   #5
Carol H's Avatar
Don't take my word for it but it has been my understanding in camping with a lot of Boler Peeps that the trailing arm on the Boler started out new with the arm level with the frame.
Steve, do you have any photos of the trailer with the wheels on it sitting on the ground to share?
Other indicators that you need a new axle are uneven tire wear, lack of clearance (a hand wide or less) at the top of the tire to the wheel well, black marks on the wheel well indicating the tire has been hitting it on bumps.
Old 08-20-2014, 06:11 PM   #6
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
The axle seems to be a real dog, therefore it must be pooched.
Old 08-21-2014, 05:44 PM   #7
Jim Bennett's Avatar
Moved the vocabulary discussion to a new thread, to allow this one to get back on topic.
http://www.fiberglassrv.com/forums/f...ord-66054.html
2017 Escape 5.0 TA
2009 Escape 19 (previous)
axle, boler
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
