Boler door seal - Fiberglass RV
Old 01-30-2017, 09:26 AM   #1
Trailer: Trillium 1979 13ft.
Boler door seal
Picked up a Boler recently and there is no door seal on the body or the door itself. When I add a seal, does it go on the door or body shell? Pros and cons...
Butsky is offline   Reply With Quote
Old 01-30-2017, 10:36 AM   #2
I've put the rubber around the door on the shell itself I have done three trailers this way seems to work fine
Philmay1 is offline   Reply With Quote
Old 01-30-2017, 04:14 PM   #3
bullfrogeh's Avatar
The door seal on our 1973 Boler is merely a common 'spongy' weather seal, and it mounted on the body shell, not the door. Easily replaced for about 'a buck-and-a-half'; but there is no such seal across the bottom, which hasn't caused any significant problem to date. I'm not sure if that simple seal was 'original', when I acquired this TT !
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 01-30-2017, 04:48 PM   #4
Ian G.'s Avatar
Although the seal can go on either the door or the door opening, it is best to mount it around the door opening for one simple reason. he seal stuck to the door frame prevents water than runs against the seal from leaking into the trailer. If you put the seal on the door the slightest gap where the seal contacts the door frame will allow water to enter
Old 01-30-2017, 04:53 PM   #5
Door seal
Well folks, the shell was my first pick, and I am glad you all agree! That is where I will stick it. Hope it stays stuck in the corner bends. Cheers!
Old 07-09-2020, 03:44 PM   #6
Boler Door Seal?
Anyone have advice where to buy one of these in discussion. I am seeing leaks through my door seal. The previous owner put the foam on the door but I would like to buy a seal similar to what you are suggesting. Appreciate all your comments, Rob
shorty13 is offline   Reply With Quote
Old 07-09-2020, 03:48 PM   #7
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
This is what I got for my Boler. I have not installed it yet(hopefully in a week or so).
https://vintagetrailersupply.com/gas...ength-vts-229/
Old 07-09-2020, 03:51 PM   #8
Hi Alex thanks for this. Was this recommended by someone who tried it? Thank you again! Rob
Old 07-09-2020, 03:53 PM   #9
Alex Adams's Avatar
New Hampshire
I read through the reviews and there were multiple Boler owners who rated it highly. At the time I bought it I also had a coupon for a discount. I have bought other seals for my windows from Vintage Trailer Supply along with other things and have had no issues with their quality or service.
Old 07-09-2020, 07:15 PM   #10
Trailer: Boler 1300
I recently got this trim from Amazon. Installed easily on my 73 Boler on the door opening and is working well.
bobdobqb is offline   Reply With Quote
boler
Boler Door Gasket/Seal question Guy with a Boler Care and Feeding of Molded Fiberglass Trailers 7 03-03-2020 07:24 PM
u-haul door seal Terry G. Problem Solving | Owners Helping Owners 13 06-07-2016 10:04 AM
Boler door seal RogerH Problem Solving | Owners Helping Owners 3 04-02-2012 06:33 PM
Boler Door Seal RLP Problem Solving | Owners Helping Owners 4 04-01-2011 07:14 AM
Burro Door Seal Legacy Posts Problem Solving | Owners Helping Owners 8 02-12-2003 01:39 AM
