79 trillium 4500 'bucking' - Page 2 - Fiberglass RV
Old 12-23-2014, 11:28 AM   #21
Trailer: Trillium
Saskatchewan
I pull my 4500 comfortably with a vw jetta, something funny is going on if you're getting that much bucking. I wouldn't jump straight to replacing axles tho, start with the cheap/easy stuff.
I'd go tow vehicle back,
1) is the receiver hitch tight on the tow vehicle? (i used to have one that would move making noises that sounded way worst than they should have)
2) is the ball the right size for the trailer?
3) is the coupler adjusted properly for the ball
4) do you have enough tongue weight? (mine pulls better with a battery and propane tanks mounted)
5) tire pressure? free to check
6) suspension condition
7) Frame condition
dbir is offline   Reply With Quote
Old 01-25-2015, 09:51 PM   #22
Trailer: 1978 Trillium 4500
One more point to add to Dales.
8. Is the Ball on tight.
We had a horrible first week towing in the cascades and discovered that our ball was coming loose. Tightened it up and no more bucking!
Old 01-25-2015, 10:50 PM   #23
EcoHeliGuy's Avatar
Also your Jeep is a unibody. As a result any slop in the connection sounds really loud compared to an older body on frame. I always use a hitch clamp on a unibody.
Also tighten the coupler with the hitch removed from the tow vehicle. Clamp the coupler to the hitch, keep tightening the coupler nut until there is just enough friction on the ball it starts to resisted moving with hand pressure on the hitch. Then try the latch a couple times. If latch isn't working smoothly, very slightly loosen off the nut until the latch works every time. This is the perfect clamping force
But my money is on hitch hight and hitch weight.
Sent remotely
EcoHeliGuy is offline   Reply With Quote
Old 02-09-2015, 01:17 AM   #24
OscarD's Avatar
Trailer: Trillium 4500 Jubilee 1979
My 1979 4500 original axle that was removed had 1200 stamped on it.
I believe the axle was minimal.
Bucking was always a problem; with LOTS of weight forward it lessened.
After installing the Timbren Axle-less Axle we've been on two trips and the trailer is not bucking. First noticed going over a rail track which would have had the trailer airborne before. Potholes did the same. It is safer now and I wish I had thrown out the 36 year old axle when it was "straightened".
This should link to the post.. Offroad best axle?
http://www.fiberglassrv.com/forums/f...xle-67402.html
OscarD is offline   Reply With Quote
Old 02-09-2015, 09:33 AM   #25
David Tilston's Avatar
My 1978 4500 had 2000lbs stamped on it
trillium
Scamp 5th wheel "bucking" on uneven surface ? Westcliffe01 Towing, Hitching, Axles and Running Gear 15 11-12-2013 11:29 PM
CA | For Sale: Trillium 4500, Santa Barbara. $4500 SOLD! tellis Classified Archives 7 09-04-2013 11:07 AM
AB (Canada) - Trillium 4500 - 1978 - $4500 David Tilston Referrals: Molded Fiberglass Trailers 16 04-22-2013 01:07 PM
"Bucking" feeling while towing in-town (trillium 1300/volvo 245) coalminecanary Towing, Hitching, Axles and Running Gear 12 10-18-2011 11:59 AM
1979 Trillium 4500 for sale -- C$5200 or US$4500 - SOLD jenniferm Classified Archives 8 07-14-2009 01:38 PM
