We are selling our beloved
Casita trailer, sized perfectly to fit in a standard garage with an eight-foot door. I would say it is better than new with the modifications that were done. You will find real wood doors and cabinets instead of pressboard. There is also an option to turn the bench seat into bunk beds which provides an option to sleep 4 in this trailer.
This is a custom restored 16-foot Luxury Traveler with bunk beds, shower, and toilet. It had a frame off restoration started in 2002, finished in 2005. Some additional modification and upgrades since then but 90% done in 2003-4. The
fiberglass cab was removed from the frame and stripped to bare
fiberglass inside and out. The door and all
windows were removed and each completely disassembled, all parts refurbished and the everything then re-assembled.
Fiberglass shell was completely gutted, all cabinets and interior fixtures removed.
• Wood floor was removed down to the fiberglass and replaced with new treated plywood then new short nap outdoor patio carpet installed.
• Walls were re-carpeted with gray cut pile carpet with 1/2 inch foam Konga backing that
Casita recommends.
• All fiberglass cabinetry was reinforced and refinished before installing.
• All wood was replaced with custom finished birch plywood, stained and then three coats of hand sanded spar varnish.
• All cabinet hardware was replaced with new chrome hinges and locks.
• New wiring harness with 10 gauge main wiring.
• Klevin Enterprises Inteli-power 60 amp Converter/Charger with
battery wizard.
• New plumbing with Flojet Quiet Quad 11 water pump and new 110 and gas water-heater.
• New Fantastic Fan ceiling vent.
• New additional ceiling exhaust fan vent added in the bathroom.
• Six additional interior
lights were added in addition to a closet ceiling
light.
• Additional outside
lights were added in front and back to help in backing up and unhooking after dark.
• New AC was replaced in 2007.
• 2.8 Gal gray water tank added to kitchen sink.
• New oversize wheels and
tires (used less than 800 miles).
• New Ele land line storage port.
• New city water port with pressure regulator.
• Custom storage cabinets.
• Original Dometic
refrigerator, 110, 12 volt, and
propane.
• Privacy shades.
