1982 Boler remodel, rebuild, restore - Page 5 - Fiberglass RV
Old 04-30-2015, 03:29 PM   #81
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
great jod
can you do my trailer lol
MRClaus is offline   Reply With Quote
Old 04-30-2015, 05:24 PM   #82
Raff's Avatar
Originally Posted by summersucks View Post
Wow, your camper is amazing.
I have a couple of questions for you.
This one is kind of lame but where did your wife find those bins? Do they have baskets that fit into the tops? Am I seeing that right? They look perfect and I want them.
The second, your countertop trim, is that screwed in? Is that how you attached it? Thanks so much!
Thanks for the kind words. My wife found the storage bins at a store called Solutions. They have a bunch of locations in Ontario. I'm not sure about Alberta. I made the bed area to fit the bins.
https://www.solutions-stores.ca/ecommerce/control/main
The counter edging came from Vintage Trailer Supply. The Home Depot has very similar stuff. It's carefully bent around the curve of the counter and screwed in place.
Raff is offline   Reply With Quote
Old 04-30-2015, 05:40 PM   #83
Raff's Avatar
If I charged you for the hours I put in you'd be broke. If I charged by the value of the job I'd likely starve to death 😎
Old 05-30-2015, 02:55 AM   #84
Raff's Avatar
Greetings all. It's been a while since I've done any work on the Boler and it's time to get back at it. At the moment I have the axle out and a new one on the way. I've emptied out the interior once again and I'm starting the job of painting the interior. I've checked lots of threads here and I'm painting the interior cabinets and ensolite with a good primer followed up with a good quality paint. I've also put in a new backsplash which is made for a sheet of plastic type material that I got at Home Depot. It comes in 4x8 sheets. I've only used a small section for the backsplash so if anyone is near Toronto and could use the remainder you're welcome to it. The colour of the cabinets and the ensolite will be the same as the backsplash which I guess you would call putty. The cabinet doors will be painted a contrasting colour which we haven't chosen yet. My wife will be sewing up some new curtains as well. I also picked up a box of laminate flooring that I found on sale and will be putting that in after the painting is done. Pics as we go for anyone interested.
Name:	ImageUploadedByFiberglass RV1432976047.166465.jpg
Name:	ImageUploadedByFiberglass RV1432976075.716349.jpg
Name:	ImageUploadedByFiberglass RV1432976120.477241.jpg
Name:	ImageUploadedByFiberglass RV1432976149.869958.jpg
Old 06-09-2015, 03:22 PM   #85
Raff's Avatar
I just got my new axle today. I ordered it from a local trailer place that takes the measurements I provided and has the axle made to order. Rated for 2000-25000lbs has Flexride adjustable arms and Dexter brakes. Looks pretty good. $360 taxes in. I put it under trailer to check the fit and it's great except the mounting brackets are 1/2" shorter than the originals. As a result the axle tube hits the frame before the bolts are snug. Tomorrow I'll pick up some bar stock, drill a few holes and sandwich it between the axle and frame.
I noticed the pics disappeared from my previous post. Not sure how that happened. Anyway the interior painting and laminate floor installation is almost done. I'll post a few photos when complete.
Name:	ImageUploadedByFiberglass RV1433884923.815627.jpg
Old 06-09-2015, 03:42 PM   #86
Ian G.'s Avatar
Also be aware the Flexi Ride axle arms are 1.5" shorter than the original Dexter (4.5" vs 6"). What this means is if you mount the axle in the same location the wheels will be offset 1.5" from the center of the wheel well opening.
Also make sure the brakes are on the correct side, if you are installing as a leading arm configuration the brakes are probably installed by the manufacturer as trailing arm, you need to swap brake backing plate assemblies side to side so the rotation for the magnet and arm are correct.
Old 06-09-2015, 03:45 PM   #87
Raff's Avatar
Thanks Ian. I'll look into that before final installation.
Old 06-13-2015, 03:44 PM   #88
Raff's Avatar
Got the axle installed today. I solved the mounting problem by getting a couple of pieces of solid aluminum 1 inch thick, drilling some holes and sandwiching it between the frame and the axle mounting pad. It worked perfectly and the axle was bolted in with no issues. Ian, the trailing arms were a bit shorter than the original but it still looks ok. Now I think the trailer sits too high. In the attached pic it's still sitting on some wood blocks so is haven't yet decided if I'll pull off the trailing arms and change the angle. With the old collapsed axle the trailer was close to scraping the pavement on numerous occasions, that's not going to happen now. Changing the angle of the trailing arms looks easy so I'll see how it looks when its attached to my TV. Ignore the outside of the trailer. It hasn't seen soap since last fall. A thorough sanding and a roll and tip paint job are on my list.
Name:	ImageUploadedByFiberglass RV1434231797.947566.jpg
Old 06-13-2015, 03:51 PM   #89
Raff's Avatar
Also finished up most of the interior painting and the installation of the laminate floor. Thought I'd post a few progress pics. I still have to do some final touch ups. I'm missing a handle or two. My wife is going to be making new curtains the interior needs a good cleaning and the mattress put back in.
Name:	ImageUploadedByFiberglass RV1434232060.726498.jpg
Name:	ImageUploadedByFiberglass RV1434232087.191512.jpg
Name:	ImageUploadedByFiberglass RV1434232116.424329.jpg
Name:	ImageUploadedByFiberglass RV1434232171.859156.jpg
Name:	ImageUploadedByFiberglass RV1434232195.678636.jpg
Name:	ImageUploadedByFiberglass RV1434232221.611731.jpg
Name:	ImageUploadedByFiberglass RV1434232251.547622.jpg
Old 06-13-2015, 05:32 PM   #90
D Davis's Avatar
Virginia
Dang! This looks great! Superior job!
Old 06-14-2015, 01:16 PM   #91
Raff's Avatar
Thanks for the compliment. Definitely couldn't have done it without liberally borrowing from all the great threads here.
Old 06-14-2015, 01:55 PM   #92
Trailer: 1976 Trillium 1300
Love the colours, very classy.
Old 06-14-2015, 02:36 PM   #93
Jay H's Avatar
Trailer: Boler 1300
that looks Great Martin!
Old 06-14-2015, 03:30 PM   #94
Raff's Avatar
Thank you both. My wife picked the colours. I just agree and it all works out. 😊
Old 07-07-2015, 09:57 AM   #95
Raff's Avatar
I pulled the trailing arms off the new axle this morning in an effort to lower the ride height a bit. Turned out to be a simple job. 20 minutes per side. One bolt, a little persuasion with a hammer and the arm was off. I used the marks punched on the spindle to make my adjustment. It's about 1 1/2 inches lower. I would recommend the adjustable trailing arm axle to anyone doing a swap. I haven't towed with it yet but so can't comment on that.
Name:	ImageUploadedByFiberglass RV1436284572.382569.jpg
Name:	ImageUploadedByFiberglass RV1436284612.927501.jpg
Name:	ImageUploadedByFiberglass RV1436284628.102030.jpg
Old 09-12-2015, 09:54 AM   #96
Raff's Avatar
While I didn't get to do all of the jobs that I had planned to this summer I did manage to finish painting the interior, add some Umbra coat hooks, install the vinyl flooring and fill and sand the rivet holes in the body. The gel coat is faded and chalky and could really use a paint job but that will have to wait. Instead I gave the whole trailer a wet sanding with 600, 1000 and 1500 grit sandpaper and then washed and waxed it. It looks pretty presentable now both on and out. My wife got the interior sorted out and sewed up all new curtains. We leave next week for a two week trip. We're making a straight shot for the Florida Keys staying at Long Key State Park, Boyds in Key West and Anastasia State Park in St Augustine. I'll do a thread on the trip for anyone who might be interested.
Name:	ImageUploadedByFiberglass RV1442073143.278078.jpg
Name:	ImageUploadedByFiberglass RV1442073178.211326.jpg
Name:	ImageUploadedByFiberglass RV1442073219.532522.jpg
Old 09-12-2015, 01:34 PM   #97
D Davis's Avatar
Virginia
Martin, of cource we are interested in your trip. Have a wonderful time and be safe. Your camper is marvelous! (I envy all your cabinet storage.)
Old 09-12-2015, 02:25 PM   #98
emij's Avatar
Trailer: 2005 Scamp 16
Looks great! Look forward to details of your trip! Enjoy!
emij is offline   Reply With Quote
Old 09-12-2015, 05:37 PM   #99
Jay H's Avatar
Trailer: Boler 1300
Martin, Your trailer looks great. I especially like the redesigned kitchen cabinets. I never liked the odd sizes of the original design. I am however going to have to wait for the kids to grow up before I can add a microwave to mine.
Have a great trip and enjoy your trailer!
Old 09-20-2017, 05:49 PM   #100
fofobraselio's Avatar
Trailer: 13' Boler
Absolutely love following your build, always motivating to see what others are up to and how deep their own renovations are going.
fofobraselio is offline   Reply With Quote
boler
1982 Fiber Stream Rebuild Victor Benz Modifications, Alterations and Updates 18 07-02-2015 01:55 AM
BC | 1974 boler 13' restore project for sale$3500 Bcboler Classified Archives 0 04-20-2013 09:07 AM
1974 Boler Restore - Penticton BC Bcboler Modifications, Alterations and Updates 21 11-04-2012 03:03 PM
Restore boler 78 Yvon Chayer Modifications, Alterations and Updates 36 04-22-2012 09:28 PM
Our 1973 Eco - with recent retro restore Mark and Peg P. Modifications, Alterations and Updates 4 07-14-2008 06:17 PM
