Painting a Boler with Interlux - Fiberglass RV
Old 09-02-2014, 05:26 AM   #1
EwaW's Avatar
Trailer: 1974Boler
Looking for suggestions when painting a Boler with Interlux. I am planning to tape off the windows and remove the door and smaller hardware.
EwaW is offline   Reply With Quote
Old 09-02-2014, 08:15 AM   #2
Bob Miller's Avatar
Trailer: Class A Motorhome
Take out the windows, vents and anything else that is attached to the body. Here's why:
1. There already is a sealant of some sort between the frames and the fiberglass. This will make a boundary that the Interlux (or any other paint) may not like and can result in peeling. Remocving everything, painting and then sealing will provide a better and longer lasting paint job.
2. As you just bought the trailer, there is a good chance that the windows and other openings haven't been resealed in years, meaning it's time to do it again. BTW: We never use silicone type sealants on FGRV's. You want to get RV Butyl sealing tape from you local RV dealer or on-line.
3. If there is already all kinds of sealing goop piled on, this will give you the opportunity to remove all of it.
Old 09-04-2014, 07:57 AM   #3
MCDenny's Avatar
Trailer: Lil Snoozy
Lots of different Interlux products. I use Brightsides (one part poly product) on my boats and it's easy to use, looks great and is long lasting.
Petit Easypoxy is a competitive product a lot of boat builders like too.
My advice, get the Interlux tech literature for your chosen product and FOLOW THE DIRECTIONS. Generally sand, use proper primer, sand, apply 3-4 thin coats of topcoat. Roll and tip If you are not spraying.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
boler, paint, painting
Alberta Source for Interlux paint Peggy Problem Solving | Owners Helping Owners 5 11-06-2008 09:06 PM
Interlux users.. how much should I order? Geoff W Care and Feeding of Molded Fiberglass Trailers 3 04-25-2008 07:07 PM
Interlux Brightside - $10/qt. Angelo F. Classified Archives 0 03-24-2008 09:48 PM
Some Advice for Painting with Interlux Brightside Janine Problem Solving | Owners Helping Owners 2 08-04-2007 06:23 AM
ICI DEVOE or INTERLUX BRIGHTSIDE Paint for Boler? Suzanne P. Care and Feeding of Molded Fiberglass Trailers 16 07-13-2007 04:39 PM
