Restoring a Uhaul Burro - Fiberglass RV
Old 07-14-2014, 04:52 PM   #1
Trailer: Uhaul Burro
Hello, I just bought a 1985 U haul Burro 13 ft & need to know where I could get wiring, plumbing details or original floor plans fro?
Any help is appreciated.
Diamondgoy
Diamondgoy is offline   Reply With Quote
Old 07-14-2014, 05:03 PM   #2
Is it a Uhaul or a Burro, can't be both although they are similar. If it's a Uhaul all the cabinet doors will say so, plus multiple other places. There is a facebook group dedicated to Uhaul campers only and lots of good info there.
Old 07-14-2014, 07:40 PM   #3
I understand as there as you say Uhaul emblems everywhere, but on the right rear side there is a faded "Burro" label on it so that's where I was confused.
Thank!!
Old 07-14-2014, 08:02 PM   #4
Green Frog's Avatar
Trailer: '83 Burro
Virginia
i'm going to guess somebody put a Burro label of some sort on an early U-Haul trailer, a design that is indeed very similar to the Burro. As far as a wiring diagram, you might look at the Burro section and find the pdf of the original Owner's Manual available there. You will find a Burro wiring diagram in that which should be correct or at least adaptable to your U-Haul. Unfortunately, I know of no such information specifically available for the U-Haul. Plumbing was pretty rudimentary and should be the same for both. As far as the floor plan, since the cabinets, benches, etc. were moulded in and part of the structure of the trailer, all you need to worry about is what colors of carpet, curtains and cushion covers you want to use. How about in progress photos of your build?
Froggie
Green Frog is offline   Reply With Quote
Old 07-14-2014, 09:05 PM   #5
You can access the repair and maintenance manual for Uhaul in the document center here or on the Facebook group . We just made a file about common issues and info about Uhauls on the Facebook group. Some good info there. The light wiring for Uhauls is a little different in that there were two leads running up the tongue, to feed lights on each side of the trailer. Tail lights and marker lights that is, if your wiring is original. I totally rewired ours. You need to read that file on Facebook, then ask questions from there.
Old 07-14-2014, 11:56 PM   #6
gage's Avatar
Trailer: 13' Burro
A quick way to tell what you have Warren is a Burro has round tail lights and a U-Haul has flat tail lights.
gage is offline   Reply With Quote
Old 07-15-2014, 06:10 AM   #7
CindyL's Avatar
Trailer: 16 ft U-Haul VT
The side of a Uhaul has a flat place that extends to the back where the taillights are. It allows for the placement of the Uhaul stickers. The side of a Burro has a V-shaped extension to round taillights that will hold no label.
Our Uhaul VT came with 3 pine trees painted on the side to make it resemble a different kind of camper. (Not there now.)
CindyL
burro, uhaul
Restoring Our 1972 Boler American Roy in TO Care and Feeding of Molded Fiberglass Trailers 58 05-17-2016 05:05 PM
Restoring the Finish on Bigfoot DwayneR Care and Feeding of Molded Fiberglass Trailers 9 05-14-2009 02:05 AM
Restoring my 1980 13' Scamp sherry loving o Care and Feeding of Molded Fiberglass Trailers 22 05-30-2008 12:49 AM
looking for a book on restoring a 15' Beachcomber fibreglass trail Dollard LeBlanc Care and Feeding of Molded Fiberglass Trailers 7 05-24-2008 05:16 PM
Restoring a Play-Mor II ('87 I think) Geron Modifications, Alterations and Updates 9 05-08-2008 08:23 AM
