83 Burro door hinge fell off - Fiberglass RV
Old 07-24-2019, 08:37 PM   #1
Trailer: 83 Burro
Illinois
Last weekend, when I was showing a friend my Burro, the top door hinge came off. Luckily, this happened when it was sitting in my driveway, and not while I was driving. I found some posts on this site that were very helpful. There is a wood block inside the fiberglass that rotted away. Some people fixed it by cutting the outer fiberglass shell, and some by cutting the inner fiberglass. After looking at my Burro, I decided to cut the inner fiberglass, remove the rotted wood, cut some new wood out of oak scraps I have, fiberglass the wood and re-install it. Then I'll patch over the fiberglass behind the top hinge. The lower hinge is in the compartment below the seats, so I may just give it a rough patch. It will be difficult to cut the fiberglass behind the lower hinge because I'll have to work upside down with my head sticking in the compartment below the seat. But the easy patch job should make up for that.
If anybody has any advice or sees problems with my plan, please let me know.
GWMattson is offline   Reply With Quote
burro
7" Brakes clip that keeps magnet on arm fell off? DogHaus Towing, Hitching, Axles and Running Gear 18 03-23-2018 04:12 PM
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 12:39 PM
Door handle fell off in my Boler Emilie W. Problem Solving | Owners Helping Owners 4 01-20-2015 08:56 PM
Broken axle help in Lafayette, LA? (was: whee l fell off (mostly)) CeliaL Problem Solving | Owners Helping Owners 27 03-23-2011 08:31 AM
Potable fresh water tank spigot fell off brendaross Problem Solving | Owners Helping Owners 1 09-18-2007 05:13 PM
