Leaky Dump Valve - Fiberglass RV
Old 08-30-2016, 10:52 AM   #1
Trailer: In the market
Leaky Dump Valve
Noticed my waste dump valve leaking on my 21' RB Bigfoot. I looked underneath to attempt a repair and found all plumbing is concealed by a underside pan. Has anyone replaced or repaired the dump valves on their Bigfoot trailer? Any advice would be helpful.
Bruce Ebling
Bruce Ebling is offline   Reply With Quote
Old 08-30-2016, 12:27 PM   #2
floyd's Avatar
I haven't seen your valve or your trailer, but a common dump valve is glued to the drain line.
The good news is that there are four screws on the flange so the valve can be disassembled. You could clean it but it is easier to buy a new valve and disassemble it. Reassemble using all the new parts except the inlet side which you can just clean. A little care must be taken with the rubber o ring. Use a little silicone grease for assembly lube. This is a simple repair which can avoid cutting and gluing.
All this assumes that the valve looks like this...
Old 08-31-2016, 04:26 PM   #3
Ttocs M's Avatar
Trailer: Formerly Scamp
Floyd, you're hired! Thanks.
Ttocs M is offline   Reply With Quote
Old 08-31-2016, 09:51 PM   #4
Trailer: G30 Elite Class C
Thank goodness we now own a MH
: changing that valve to a new one was the easiest job my wife ever did, she just made sure the tank was empty first or there would of been one heck of mess.
also we have easy access as no laying on back when doing the work.
stude
bigfoot
dump valve - leak at knife valve DogHaus Problem Solving | Owners Helping Owners 3 09-29-2011 11:30 AM
Dump valve rearrangement? Joe in MN Plumbing | Systems and Fixtures 10 10-20-2010 06:58 PM
Relocated dump valve Mike Taylor Modifications, Alterations and Updates 3 11-14-2005 03:26 AM
Leaky Vents Legacy Posts Problem Solving | Owners Helping Owners 9 04-12-2003 12:13 PM
Public Dump Sites Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 04-03-2003 05:04 PM
