New door seal from Scamp - Page 2 - Fiberglass RV
Old 07-15-2015, 05:11 PM   #21
Jon in AZ's Avatar
Originally Posted by Rich G. and Val F. View Post
The kick plate goes all the way across. It is made of a hard plastic or vinyl. It fits over the rat fur and under the door edge trim.
Thanks for sharing the picture. I wondered what it looked like. I had hoped it would extend farther up the door. No matter what I do, the bottom 12-15" of the door seems to get dirty. Road splash works its way in and the bottom curves out when the door is open. Thankfully, rat fur is cleanable, but an easy-wipe surface would be even better.
Old 07-15-2015, 05:44 PM   #22
CampyTime's Avatar
Trailer: Scamp 13' Standard
Does anybody know if that new black plastic/vinyl kick plate for the door is available on scamps website to order? The rat fur on the bottom of my door always gets damp and dirty. I have scamp's other rubber seal on (d shaped) and it works fine but only have that itty bitty corner piece of a kick plate on the door.
Can't seem to get on to their parts store tonight myself. Keeps coming up a blank page on the web.
Old 06-30-2017, 11:51 AM   #23
Trailer: 2009 Scamp 16
Originally Posted by ScampingInSeattle View Post
We did ours the same way, laid it around the rounded corners at the top of the door and cut a separate strip for the bottom of the door. Seems to be working really well.
The seal goes on the door frame, not the actual door. You have to remove the old foam gasket, making sure to get all of the adhesive off. That was the worst part of the process but it was definitely worth it, the new seal is so much better!
What did you use to remove the old adhesive and also to adhere the new seal?
EFISHNSEA is offline   Reply With Quote
Old 06-30-2017, 12:46 PM   #24
floyd's Avatar
I use a soft white cotton T-shirt material and Brakleen... then wipe it down with Isopropyl alcohol.
The gasket comes with self stick on the mounting surface which works well on a clean dry surface.
if you scrape at the old adhesive, use a plastic scraper, not metal.
Scamp Door Seal ericw Modifications, Alterations and Updates 13 11-09-2020 06:00 PM
New Scamp Rib Door Seal TomK Modifications, Alterations and Updates 36 09-21-2018 07:34 AM
New door seal source? msinger919 Problem Solving | Owners Helping Owners 5 08-03-2013 08:03 AM
door on `98 scamp won't seal fusedlight Problem Solving | Owners Helping Owners 12 07-15-2013 08:33 AM
Scamp Door Seal Parker Buckley Problem Solving | Owners Helping Owners 16 10-11-2011 09:55 AM
