10-16-2017, 12:39 PM
#41
Trailer: Scamp 13
Propane Regulator Mounted Wrong
Originally Posted by gordon2
Well now so am I... Anyone who bought or does buy a new Scamp, please let us know if your propane regulator has a cover. Photos would be great!
Hi Gordon,
Thank you for the heads up on the propane regulator. I have a 2016 Scamp 13 and checked it this weekend and mine is also mounted incorrectly and has no covers on it. I also read the warning right on the MEGR-298 and it said to mount it down. Mine is mounted at 9 o'clock so I guess it is within 90 degrees of down but not good enough. I guess I will have our RV guy remount it correctly but one of the lines is not long enough to do so and will have to be replaced. Eeeeks.....what would it have cost Scamp to mount it correctly!
Thanks again,
Susan
10-17-2017, 04:50 AM
#42
Originally Posted by SusanandPierre
Hi Gordon,
Thanks again,
Susan
Can you post a photo?
I think if I were you I might check with the manufacturer of your reg to see if a cover is available. I think it you can get a cover over the larger second stage vent, that would be good enough.
Is you regulator the MEGR-298? Then the MEGR-862 cover should be all you need even if it is mounted with the vent vertical (unless maybe the vent is facing forward and you drive into rain, but that is unlikely). Of course that is just my understanding. Follow the advice of professionals over mine.
10-17-2017, 10:54 AM
#43
Originally Posted by Borrego Dave
... Any particular reason the reg is installed with part of it below the frame rail instead of even or above it for a little protection from road debris?
After sleeping on this question, today I changed the mount as show using the metal plate that Scamp originally had screwed to the frame with two small screws. This is still a no-holes-in-the-frame mount.
10-17-2017, 03:34 PM
#44
Bingo, from the pic, it looked like it could be repositioned higher on the same bracket .
10-17-2017, 04:37 PM
#45
Not with the current hardware (the photos are not that good), but its good to go now. In fact i can push and pull on the regulator and get the trailer to rock. Its a solid mount and the hoses are not under undo stress. The cover(s) are likely not needed now but they are so cheap, why not.
10-18-2017, 07:56 AM
#46
Trailer: Scamp 13
Hi Gordon,
Here is a picture of ours on the 2016 Scamp 13. I know for a fact, it did not come with a cover on it. I do not want to drill any holes, I may just try buying the cover and keep an eye on it since it is mounted at 9 O'clock. Yes, it is the MEGR-298.
Sincerely,
Susan
10-18-2017, 08:02 AM
#47
Trailer: Scamp 13
Ooops...here is my picture.
10-18-2017, 08:22 AM
#48
Missouri
sort of
sort of like ours but ours just hangs there and goes to the flare fitting on the trailer!
bob
10-18-2017, 09:00 AM
#49
Hi Gordon,
Sincerely,
Susan
Yup, unless a pro says otherwise.. get a cover and I am sure you will be fine. The cover is all of $5.95 shipped at Amazon and $1.59 at RV Supply Parts not including shipping.
I dont think you need the smaller first stage cover also since the very small first stage vent is facing down in your case.
10-27-2017, 11:39 AM
#50
Took the following pic while at the Scamp factory. All of the single tank units had the opening facing rearward and the dual tanks were mounted with the opening facing down as shown in the following.
10-27-2017, 12:55 PM
#51
Missouri
thingees
dave just the way I have mine installed now. I went from a 2 tank to a single tank had to buy a new one. the other one was 22 years old a good long time of use in my book.
bob
10-27-2017, 06:29 PM
#52
Trailer: Trillium 2010
Timely thread
Last fall my dometic 2193's performance was not what it should be. This spring I serviced the burner and replaced the regulator. This put the operation back to normal until this fall where again things deteriorated. Again I serviced the burner. Since the regulator was new I decided to check the pressure. This morning I built a manometer and connected it to the gas line. I expected to see 11"wc. I opened the gas and the water blew out the open end of the tube. Near as I can figure the 2nd stage of the regulator must be shot after one season. The regulator is installed in the correct orientation and has the protective cover. It is a Marshall 291 made in the U.S. Done for the season so I've got all winter to figure it out. Any thoughts would be welcome. Raz
10-27-2017, 08:35 PM
#53
Raz, While I applaud your initiative to build a manometer (something I have considered doing), if I got a crazy reading then I might question it, and take the camper to a professional with a quality gauge. At the same time they could do the other checks such as pressure drop, and flow / load, to insure that the system is up to specs.
My other thought is that even if your reg is fairly new and properly installed, it could still be bad. If you think it is then you might replace it before going for the testing, or just have the system tested first and replace the reg if needed.
10-27-2017, 08:54 PM
#54
Missouri
wow
you are a pretty smart guy to do that!
bob
10-28-2017, 04:11 AM
#55
I will replace the regulator. They are suppose to be calibrated from the factory. If I don't get the expected results then maybe an HVAC guy. I've got all winter to noodle on it. .
10-28-2017, 04:13 AM
#56
bob
Others would say what are you nuts
10-28-2017, 06:10 AM
#57
Good plan. Yes, they should be properly adjusted from the factory. So I wonder, will you check the new one with your manometer? It would be interesting to see if you get different results. I would like to have that tool in my arsenal also, and building it is one option although I would probably buy something.
10-28-2017, 06:35 AM
#58
A manometer is very accurate as long as your measurements are correct. It is what is used to calibrate the gauges. Just don't use centimeters instead of 1/2" increments. The OEM was a Marshall 290, no longer made. The 291 is the direct replacement. I assumed it was US made as the OEM was but the company is now Marshall Excelsior so who knows. Amazon sells a Mr. Heater made in Italy. A close examination of the picture seems to indicate otherwise.
10-28-2017, 06:57 AM
#59
Missouri
regulator
i think mine is a mr buddy came with the hose and regulator the original was 22 years and showed no rust I just wanted a single tank system. you guys with enquiring minds amaze me sometimes. you must have a background in this stuff.
as for the rust problems and things I think I would buy the whole tank enclosure thingee and be done with it.
This would resovle all water issues entirely plus I think they look sharp on a 2 tank system!
bob
10-28-2017, 08:38 AM
#60
... The OEM was a Marshall 290, no longer made. The 291 is the direct replacement. I assumed it was US made as the OEM was but the company is now Marshall Excelsior so who knows.
The Marshall Excelsior catalog has a "Made in USA" tag on about every page (but maybe they mean the catalog itself LOL). I think my MEGR-298H says made in the USA on the back (underside) but I cant see it well enough to be sure without removing it.
Amazon information is terrible and often wrong (not to mention that they seem to sell used or returned items as new a lot, and a lot of knock-offs and imitations are in the marketplace). Now days I pretty much assume everything is made in China unless I have information to the contrary.
BTW, is the only difference between the MEGR-291 and the MEGR-298 the direction of the vent? And then there is the question of the high capacity versions (with H appended to model number) or not.
