Originally Posted by gordon2
BTW, is the only difference between the MEGR-291 and the MEGR-298 the direction of the vent? And then there is the question of the high capacity versions (with H appended to model number) or not.
I think you are correct, the 291 is intended for vertical mounting with the vent down where the 298 is designed for horizontal mounting with the vent down. As far as capacity the way I read it the high capacity I'd intended for large trailers with large appliances. Same pressure but higher gas flow.
I had an Amazon order ready to go in so I order another 291. When it gets here I'll install it and check the pressure. If the pressure is off back it goes.
