Propane Y-splitter Recommendations - Fiberglass RV
Old 04-09-2017, 03:47 PM   #1
Trailer: 2016 -13' Scamp
Massachusetts
Any pros and cons on specific brands of propane Y-splitters? Is there a brand that has a check valve on one side so only one hose has to be hooked up at a time? I'd hate to be leaking propane gas at the campground when I don't have my Camp Chef Ranger attached.
I've looked on amazon.com, specifically at the Bayou Classic Y-splitter but I first want to hear from the voice of experience in this collective group.
No messing around with propane!
Peg
herons is offline   Reply With Quote
Old 04-09-2017, 03:56 PM   #2
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Peg
If low pressure, the female QD fittings on the downstream side of a "Y" splitter will not flow propane if a male fitting is not inserted in them. In this case, you are visualizing a problem where one does not exist. Besides, if you only want to use one appliance and are "concerned," don't use the "Y" splitter. No reason to include a 2nd output if you only want or need one. The Bayou classic is high pressure. Appliances will need regulators. The acme fittings on the Bayou Classic will not flow propane unless something is connected. Again, no problem and again, if you only want one appliance, connect the single appliance directly to the tank without the "Y" fitting.
Old 04-09-2017, 05:56 PM   #3
Massachusetts
Good to know about the unused side of the splitter. I thought that was the case but wanted to be certain. I will cap it off when not in use to keep road debris from the threads.
My plan is to mount it for use on an every other day basis. So it's easier to leave it mounted than to take it off, put it on, etc.
Thanks for the advice.
eco, propane
Propane splitter/Y pipe options? jrocmagoo Problem Solving | Owners Helping Owners 5 08-07-2014 02:40 AM
Propane-Fueled Cook Top Recommendations E. Graham Problem Solving | Owners Helping Owners 6 07-03-2008 12:36 AM
Sway Bar recommendations Legacy Posts Towing, Hitching, Axles and Running Gear 20 05-19-2003 01:51 PM
Need Recommendations General Chat 0 01-01-1970 12:00 AM
Propane-Fueled Cook Top Recommendations E. Graham Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
