1977 Surfside, door lock - Fiberglass RV
Old 09-08-2012, 10:06 AM   #1
Trailer: 1977 Triple E
Help
Finally retired and on a cross Canada Trip and my metal door lock, will not lock. The door closes and latches, but will not lock from the inside or outside.
Currently in Vancouver BC.
Can I get a replacement lock?
Any advise is appreciated!
Cheers
Bill
William Urie is offline   Reply With Quote
Old 09-08-2012, 11:02 AM   #2
Take it apart and clean and lube it. I don't know what that trailer has for a door latch, but our Uhaul that has the big square Bargman L300, it wouldn't lock on the inside unless the key was in the center of it's travel. I took ours apart, cleaned it, and lubed it with white grease, the key still has to be in the right position to lock it on the inside.
Old 09-08-2012, 11:17 AM   #3
Thank you for your reply.
I believe the problem is in the locking mechanism, being worn?
I will need to take it apart to be sure.
Can I buy a replacement lock, somewhere?
Again, thank you.
Bill
Old 09-08-2012, 06:24 PM   #4
I don't know what that trailer uses for the door lock so I can't answer where to get one. If you can figure out what it is, then look on ebay, check out vintage trailer, and fletchers trailer sales. I was hoping someone here with the same trailer could help you. Bob
Old 09-08-2012, 07:23 PM   #5
alan in alberta's Avatar
Trailer: 2006 Escape 17 B Raven and a Pearl
my surfside has a bargman 400 so i assume yours is the same
it is no no longer made
i replaced mine with a modern one however it is quite a job.
if you are in vancouver i would say check with Escape trailers in chilliwack for advice and possible repair
alan in alberta is offline   Reply With Quote
surfside
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
1977 14' Surfside Chester Taje Referrals: Molded Fiberglass Trailers 1 05-10-2010 10:32 PM
surfside 1977 rides again! Evinger1 Problem Solving | Owners Helping Owners 5 05-17-2007 06:25 AM
1977 14 foot Surfside LaFaver Classified Archives 3 08-11-2006 09:35 PM
Need 1977 Surfside 14' Weights Raunie Aasland Problem Solving | Owners Helping Owners 2 04-24-2006 07:12 AM
