Inverter plastic switch thingamajig replacement - Surfside - Fiberglass RV
Old 07-09-2013, 11:11 AM   #1
Shelley's Avatar
Trailer: 1977 Triple E Surfside
Hi,
I have a Surfside and there is a plastic push button switch inside on the front side of the cabinet below the sink and stove which switches power from 12V to 120V (I think).
This switch is broken off and is stuck pushed in...the RV shop tells me that a different type of switch would have to be wired in.
Has anyone seen the old style of switch? Other ideas? options?
Shelley is offline   Reply With Quote
Old 07-09-2013, 06:40 PM   #2
Brian B-P's Avatar
If it is switching 12V DC power would visit an industrial and trucking supplier and check our their catalog for switches of the right voltage and current capacity. There are lots of styles, including push-pull, but they are hard to find in regular consumer retail stores.
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Broken Plastic Faucet BCPaul Plumbing | Systems and Fixtures 7 05-15-2012 11:46 AM
plastic plywood andrew78 Modifications, Alterations and Updates 9 03-20-2012 09:31 PM
Another plastic teardrop hamstercampster Referrals: Molded Fiberglass Trailers 0 07-30-2011 10:21 PM
Plastic Scraper for Fiberglass Brian B-P Care and Feeding of Molded Fiberglass Trailers 7 04-04-2006 11:24 AM
