Will 175/80R13 fit up on a Fiber Stream - Fiberglass RV
Old 07-30-2013, 03:06 PM   #1
Trailer: Fiber Stream
Maryland
Has anyone switched to 175/80R13 tires from the original tires on a Fiber Stream?
The tire overall size is 24" vs the original 22" but I more concerned about the back-set and fit of the rim on the hub. I'd use these on a suitably sized center hole 2.85 and 4 on 4 lugs.
Availability of ST175/80R13 Tire Size With 4-Lug Wheel To Replace A78-13 Tire Size on Trailer | etrailer.com
JD1994 is offline   Reply With Quote
Old 07-30-2013, 07:19 PM   #2
Brian B-P's Avatar
One of the Fiber Stream owners might be able to comment on the room available on both the back and front sides.
Although I don't know the specific reasons in this case, I understand that there would be multiple reasons to get away from the original tire size/type, which I understand to be 4.80-12. The thread Fiber Stream Wheel, Bearing Sizes discusses both a swap to 13", and the more common slight upsize to 5.30-12.
Personally, my impression is that any available 13" ST tire would be a questionable fit, and I wouldn't want to raise a trailer of mine just to fit bigger tires. In that earlier thread Frederick mentioned that Chris had swapped to 13" tires, but the exact size is unknown.
I have long thought that the logical upgrade from those old 4.80-12 and 5.30-12 tires is the 145R12 (presumably specifically ST145R12, LT145R12, or 145R12 commercial). These are tires of much more modern construction (say, 1970's technology instead of 1930's), not much larger in any dimension than the old stuff, requiring substantially less air pressure for the same load capacity. A 145R12 would fit on the same 12"x4" wheel as a 4.80-12 or 5.30-12.
fiber stream
fiber Stream Greg N General Chat 24 05-04-2014 03:04 PM
Fiber Stream jgibson Problem Solving | Owners Helping Owners 7 11-01-2012 05:13 PM
MT- 82 Fiber Stream kootenaigirl Referrals: Molded Fiberglass Trailers 22 06-18-2012 09:51 AM
79' Fiber Stream Robert N. General Chat 2 09-11-2008 07:23 AM
79' Fiber Stream Robert N. Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
