Complete re wiring of 78 surfside: Electrical question... - Fiberglass RV
Old 07-10-2014, 09:30 AM   #1
hudman's Avatar
Trailer: triple e
Hello,
Been looking for a while in the forums for any link on proper gauge wire to use for my 78 surfside complete renovation.
Anyone have any suggestions on what gauge or product I should order? I will be running a 12V system to everything and would like to know what's up to code, etc? As well as AC, but that's easy!
Thanks very much!
Chuck
hudman is offline   Reply With Quote
Old 07-10-2014, 10:36 AM   #2
When I did mine I used nothing smaller than 12 Gauge THHN Stranded wire primarily used in conduit and cable trays. It has a covering that is very tough. I also put it in a plastic loom for added protection.
Shop THHN Wire (By-the-Roll) at Lowes.com!
Old 07-10-2014, 11:11 AM   #3
David Tilston's Avatar
I use 10 gauge, but that is because I got a bunch for free. If I had to pay for it I would also use 12 gauge. Just remember to fuse it for 20A.
http://www.usawire-cable.com/pdfs/NEC%20AMPACITIES.pdf
Old 07-10-2014, 11:55 AM   #4
Timber Wolf's Avatar
North Florida
I used 12-2 w/ground "romex" for my new 120V wiring in my Scamp as I already had it on hand. I could have just as well used 14-2 w/grd as I will be using 15 amp breakers and the loads are low. For my new and replacement 12V wiring I am using this: Amazon.com: Cable Matters 2-Conductor In-Wall Rated (CM) 12 AWG Speaker Cable, 100% Bare Copper 100 Feet: Electronics which is a 12 gauge "wall rated" speaker wire. It is probably over-kill also but I usually try and go "one bump" up with my stuff if it does not cost too much more.
Old 07-11-2014, 04:44 PM   #5
hudman's Avatar
Trailer: triple e
Awesome advice guys! Truly appreciated. I'm going to check out all those links and get on buying something tonight!
Chuck
electrical, surfside
Electrical Wiring work needed Jackie R Modifications, Alterations and Updates 1 10-20-2013 08:43 PM
Wiring electrical question slbran Care and Feeding of Molded Fiberglass Trailers 16 01-19-2012 10:41 AM
SOLD - Complete cushions from Surfside $30.00 usd Deb & Chuck Classified Archives 1 07-11-2010 11:45 AM
Complete set of cushions out of Surfside trailer-$40 for all Deb & Chuck Classified Archives 3 06-17-2010 04:27 PM
Problems with U-Haul hitch electrical wiring Roger Due Towing, Hitching, Axles and Running Gear 1 04-01-2009 09:43 PM
» Trailer Showcase
Red
wel
"Scitchen"
Coby
