New 2" LED markers for burro - Fiberglass RV
Old 09-09-2015, 12:18 PM   #1
Trailer: Burro
Alabama
Does anyone have a source for 2" surface mount LED's to replace the factory side/clearance markers on the top, rear of a Burro? I've scoured the Internet to no avail. All that I'm finding are flush mount options which would require a much larger hole or surface mounts that add 1/2"-3/4" of diameter (too large). Any advice would be greatly appreciated.
nomadicitch is offline   Reply With Quote
Old 09-10-2015, 09:07 AM   #2
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Bulbs?
Hello,
Have you considered replacing the
incandescent bulbs in the light
assemblies you have with LED bulbs?
Larry
Larry C Hanson is offline   Reply With Quote
Old 09-10-2015, 09:28 AM   #3
Trailer: Burro
Alabama
I would definitely be open to that option but unfortunately all components of the light but the lens essentially turned to dust when I removed it. I thought about taking an OEM one (if I could find a temporary donor) to a 3D printer in hopes that it could be recreated. However I haven't done any real research on this so it may be price prohibitive.
Old 09-10-2015, 09:30 AM   #4
Trailer: Northern Lite
Princes Auto.??
milt is offline   Reply With Quote
Old 09-10-2015, 12:03 PM   #5
bullfrogeh's Avatar
Smile
Originally Posted by milt View Post
Princes Auto.??
Another vote for Princess Auto, for all your LED needs.
bullfrogeh is offline   Reply With Quote
Old 09-11-2015, 03:21 PM   #6
Trailer: 2000 Burro 17 ft / 2001 Toyota Tundra V8 2wd
I got these off ebay to replace the ones on my 2000 Burro. Style-wise they're pretty similar to the originals.
2 Red 2 Amber 6 LED Rectangle CLEARANCE 12V Side Marker Lights Trailer Camper | eBay
ThomasE is offline   Reply With Quote
Old 09-11-2015, 07:35 PM   #7
Timber Wolf's Avatar
North Florida
Not sure what you need but I put a pair of these and the red version on my Scamp:http://smile.amazon.com/dp/B00CEJDDP...I1L8R93IJPRCBT I see that the red is out of stock though. I know I REALLY like these for looks and brightness. My old ones disintegrated before and during removal.
Old 09-11-2015, 08:35 PM   #8
Byron Kinnaman's Avatar
Why LEDs for running lights? They're powered from the tow, or didn't you know that? Since they're powered from the tow it doesn't make a lot of sense to change them.
Old 09-12-2015, 05:10 AM   #9
North Florida
I had to change them out anyway as the plastic in the originals were crumbling and one was completely broken. Since I had to do it anyway I decided to modernize them to brighter, supposedly longer lived and lower maintainence LEDS. It is my thing that if I am going to spend time, effort, and money on a project at this point in my life I am not going to just get "back even". I plan to keep the Scamp a long time and my daughter has already "called dibbs" on it so if I can fix something with higher grade replacements parts I will do it. And yes, I think we all know they are obviously powered from the tow.
Old 09-12-2015, 06:29 AM   #10
Can you put a new bulb socket behind the original lens?
Old 09-12-2015, 09:17 AM   #11
Trailer: Burro
Alabama
Unfortunately everything but the lens crumbled upon removal.
Thank you all for your responses...I'm still searching.
Old 09-12-2015, 10:10 PM   #12
Trailer: Burro
Hey... This is what I used for my Burro. Let me know if you want me to take pics and give more detail.
2 Red LED 2" Round Clearance Side Marker Light Kits with Light and Grommet Truck Trailer RV https://www.amazon.com/dp/B00KE98FP4..._7Bp9vb2RCQQVY
'79 Burro, Rochester NY
samuelm is offline   Reply With Quote
Old 09-14-2015, 02:26 PM   #13
I installed LED lights to get rid of the problems with connections and corrosion.
Everything is encapsulated and sealed.
Most of my time fixing trailer lights has been cleaning corroded bulb connections.
No more!
Old 09-21-2015, 01:00 PM   #14
Trailer: Burro
Massachusetts
The top markers on our Burro were also toast, so we replaced them with LED fixtures. I know what you mean by having difficulty finding something that fits. I finally found cool beehive shaped red LED fixtures, designed to be replacements for Harley Davidson motorcycle rear turn signal lights. They are the same (2"I believe) diameter, and the cool bullet shape looks great on a Burro. I had to make a custom mount from a ring of PVC cut from a pipe fitting then epoxy the whole thing on. It has been in service for 4 years now and looks and works great. Very bright and very "cool".
Here is a link to what I used. I got them elsewhere but e Trailer now sells them.
https://www.etrailer.com/Trailer-Lig...s/MCL21RB.html
Rick
Old 09-22-2015, 06:18 AM   #15
I bought LED replacement running lights at Wal-Mart.
doing a search at their sight I found several examples including this one.
Blazer International LED Mini Clearance Light, Red - Walmart.com
Joe
Old 09-22-2015, 06:24 AM   #16
Doesn't matter where they are powered from, current is current.
It puts less of a load on the tail/running light circuit
Besides he indicated his crumbled
Joe
Old 09-22-2015, 06:31 AM   #17
I have installed all LED lights on my Scamp rebuild and one driving force for the running and tail lights etc is that the ones I bought are sealed and I hope that means that there are no sockets to corrode and make intermittent. Over the years this has been a problem. While I was at it all of the wiring has been upgraded and the scotchloks replaces with more reliable connections.
For me it is about longevity and reliability, not so much current draw.
Old 10-14-2015, 11:05 AM   #18
Sue and Henry's Avatar
Name: Sue and Greg
Thanks Thomas!
I lost one of the amber ones on the current Campout. Your timing is impeccable. I just put in my order.
Sue and Henry is offline   Reply With Quote
burro
Help! Side markers aren't working Lowpaidnurse Problem Solving | Owners Helping Owners 22 10-16-2011 11:45 AM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
Weights:"older model","later model" 17 ' Bigfo Joseph Olajos Towing, Hitching, Axles and Running Gear 8 04-05-2010 05:56 PM
Side markers not working Mark J Problem Solving | Owners Helping Owners 2 06-01-2008 07:28 PM
Search for "LED" Dave Mac Forum Admin, News & Announcements 4 07-14-2007 02:14 PM
