Removing Trillium gaucho - Fiberglass RV
Old 06-05-2015, 06:53 PM   #1
dleverton's Avatar
I would like to remove the goucho. The goucho sits on and is glued to a shelf an inch or inch and a half wide. My sense is that the shelf itself adds considerable rigidity. I was thinking about cutting the goucho just where it meets the shelf leaving the small section of goucho and the adhesive. I have seen Trillium's with the center of the goucho missing and I don't think the vertical panel or horizontal panel with the wooden covers add much to the rigidity. Some of you have removed your goucho and I wonder if you have any suggestions. Thanks
Doug L
Doug
dleverton is offline   Reply With Quote
Old 06-05-2015, 07:19 PM   #2
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Whatever you do, don't mess with your Gaucho!
Spanke
Trilliums Rock!
Spanke is offline   Reply With Quote
Old 06-05-2015, 09:02 PM   #3
dleverton's Avatar
You have a lot of Chiko, Harpoing on about it.
Doug L
Doug
Old 06-08-2015, 04:16 PM   #4
David Tilston's Avatar
Doug, Could you please post pictures of the shelf that you refer to?
As to removing the gaucho, Trillium made a front bathroom model. No gaucho at all. They did however put in two walls that formed something like a bulkhead. Also, as you mentioned, a front dinette version that had a gap in the gaucho.
Old 06-08-2015, 04:41 PM   #5
dleverton's Avatar
Hey David Thanks for your reply.
Name:	ImageUploadedByFiberglass RV1433803173.593954.jpg
Name:	ImageUploadedByFiberglass RV1433803054.438398.jpg
The shelf is easy to see on the outside, but not easy to see on the inside. The picture through the door crack shows it best.
I was thinking of adding a decorative wooden trim which might provide some rigidity.
Doug L
Doug
Old 06-08-2015, 07:25 PM   #6
Ah. This is a feature that the front side of the gaucho sits on, the dinette seats sit on a similar "shelf". I don't think you need to add anything. As far as I know, the gaucho adds little to the structure to a Trillium. That said, some Trillliums suffer from a sag of the front curb side corner. The gaucho may help hold it up, but since there are frequently two doors in the front of the gaucho, I don't see it providing much support.
What do you plan to put there?
Old 06-09-2015, 01:05 PM   #7
dleverton's Avatar
Hey David
The goucho is no longer.
Name:	ImageUploadedByFiberglass RV1433876666.854699.jpg
What I am installing in place is 2 leather chairs.
Name:	ImageUploadedByFiberglass RV1433876723.457176.jpg
Doug L
Doug
Old 06-09-2015, 02:17 PM   #8
The basin in your photo was intended for a porta potty.
I assume you have a large opening into your kitchen now.
Old 06-09-2015, 02:44 PM   #9
dleverton's Avatar
True. Lots of trim and finishing.
Doug L
Doug
trillium, vin
How to remove the lower Gaucho couch from its bracket on a Trillium billandkate Problem Solving | Owners Helping Owners 45 10-27-2014 08:46 PM
1993 Bigfoot Travel Trailer 17' Gaucho Floor Plan Larry Fidler Classified Archives 3 04-17-2008 08:37 AM
1990 17' Bigfoot - Gaucho floorplan $7500 Andrea in Oregon Classified Archives 13 03-25-2008 11:59 AM
Boler Gaucho Back A. Robert Reed Problem Solving | Owners Helping Owners 0 08-16-2007 12:08 PM
