1976 13' Scamp Refreshed Frame - Fiberglass RV
Old 05-01-2015, 08:01 AM   #1
Trailer: 1976 Scamp 13 ft
We have our refreshed frame back from the paint shop! We needed to replace the old axle, used a Dexter #9 and changed from leading arm to trailing arm and added electric brakes. This brought the axle under the dance floor, giving us more clearance.
The frame was sandblasted and then powder coated. The coupler was replaced with a new 2" and the jack was replaced. We also added some additional support for the dance floor, added a cross section between the rear bumper and old axle location. We also added angle iron tabs to bolt the shell to the frame instead of attaching with screws.
Now for the fun part, reattaching the shell to the frame...Click image for larger version
Name:	ImageUploadedByFiberglass RV1430488835.902236.jpg
ID:	83373Click image for larger version
Name:	ImageUploadedByFiberglass RV1430488854.350708.jpg
ID:	83374Click image for larger version
Name:	ImageUploadedByFiberglass RV1430488871.052517.jpg
ID:	83375Click image for larger version
Name:	ImageUploadedByFiberglass RV1430488886.967036.jpg
bobkatr1 is offline   Reply With Quote
Old 05-01-2015, 07:24 PM   #2
Bill Nolen's Avatar
Trailer: Had Scamp 13'.
Oklahoma
Wow! Your "new" frame and axle looks so nice!
I'm turning green with envy!
Bill
Bill Nolen is offline   Reply With Quote
Old 05-01-2015, 08:30 PM   #3
Trailer: scamp
Maryland
I'm impressed
looksplent is offline   Reply With Quote
Old 05-01-2015, 08:40 PM   #4
Trailer: Scamp - "The Haunted Mansion" (13') and TBD (16')
Looks great!
Sohkraites is offline   Reply With Quote
Old 05-03-2015, 02:38 PM   #5
Idaho
Dang. That's mighty fine.
CBinID is offline   Reply With Quote
Old 08-05-2015, 08:05 AM   #6
Trailer: 1984 Scamp 13'
Nebraska
This looks great. I would like to do the same axle swap as you. I would like to go from leading arm to trailing arm and move the axle under the kitchen floor. What down angle did you spec? Bracket type? Any special work necessary to move the axle under?
JD Eben is offline   Reply With Quote
Old 08-05-2015, 08:14 AM   #7
Ian G.'s Avatar
I have calculated the ground clearance at various suspension angles and with both the low profile and high profile brackets. You will find the Ground Clearance table about 3/4 of the way down the page Boler Rubber Torsion Axle
Old 08-05-2015, 11:04 AM   #8
Nebraska
After more investigation the last and big question for me is leading arm vs. trailing arm axle. I know there are other threads on this topic but the issue still poses a dilemma for me. Using a leading arm requires going against "modern" rules for trailers and requires reversing a trailing arm axle and brakes, etc....no warranty and getting a commercial welder to agree to do it.
While installing a trailing arm axle requires relocating it under the drop floor. The drop floor framing is not structural as is is hung from the frame and is only intended to support the flooring and cargo. Can't really attach to that - spoke to the factory. However, I'm inclined to find a trailing arm solution. If anyone has details on how to retrofit a trailing arm axle and mount it to the frame that would be really helpful.
Old 08-05-2015, 12:30 PM   #9
Trailer: Scamp 13
Looks real good. When separating the old floor from the frame did you strip down to the bare floor and unscrew all the screws or did you cut the screws in some way? Did you separate the shell from the old floor and just hack the old floor to get it off the frame? I am guessing there are allot of screws under the fiberglass tabbing where they bond the shell to the floor. I'll bet welding up and grinding all those screw holes wasn't fun.
I'd sure like to see some close up pictures where the new axle ties up to the frame. Did you use welded on mounts that bolt the axle to the frame so replacement would be easier next time?
Old 08-05-2015, 01:09 PM   #10
Ian G.'s Avatar
The axle, no matter what orientation (leading or trailing) is connected to the frame side rails, there is no connection to the floor. The axle tube mearly passes under the kitchen floor. The axle needs to be spaced down with adequate structure below the side frame rails so the centre axle tube clears the floor.
Old 08-05-2015, 07:57 PM   #11
Ian G., Forgive my ignorance on the axle issue. I'm a new Scamp 13 owner in need of an axle. I was hoping to go with a trailing arm. Will I need to move to axle to do that? And if so, do I move if far enough that it will alter the balance of the trailer. Any advice or direction is appreciated. Thanks.
FlintBound is offline   Reply With Quote
Scamp '13 Rotten Floor and Frame damage. Oliver P Problem Solving | Owners Helping Owners 12 08-22-2009 05:35 PM
16' Scamp Frame Snapped JamieB Problem Solving | Owners Helping Owners 20 08-03-2008 11:08 PM
Removing scamp body from frame Scott Corsaro Problem Solving | Owners Helping Owners 1 07-19-2008 11:24 PM
How much does the frame of a Scamp 16 weigh? WayneJ Problem Solving | Owners Helping Owners 0 07-10-2008 03:44 PM
Remove Scamp from frame rakarmes Problem Solving | Owners Helping Owners 3 11-05-2007 02:08 PM
