Boler 77 door align needs help! - Fiberglass RV
Old 08-31-2015, 08:28 PM   #1
jlbails's Avatar
Trailer: Boler 1977
After searching relevant posts, I can't find an answer so here goes.
Has anyone replaced their old Boler 2-hole hinges with a newer 3-hole Scamp hinge on the body? My door is slanted to the right, with the 1-2" gap at the bottom left. This means that the door flys open going around curves because the latch side just barely meets the door lock. The top right of the door has rubbed the gel coat off the frame.
It seems that either the bottom hinge is bent, or the body has flexed and caused the door to sag to the right. Can't tell which. If I replaced the 2-hole hinge with a 3-hole this would give the door more support (3 holes being better than 2) and help to lift the door up into place. I have already replaced the pin and balls as well as the old rusty bolts to no avail. We talked about shimming the hinge to push it out 1/8 inch, but postponed that idea.
I know I may have to re-drill 1-2 of the existing holes (or at least widen a little) and add 2 more, but it might be the best fix I can come up with.
Any other suggestions?
Thanks, Jamie
jlbails is offline   Reply With Quote
Old 08-31-2015, 09:44 PM   #2
What kind of shape is the brass spacer ball in? If it's worn down too much it can throw the alignment off. I think many have used the Scamp hinge with good success too. I would see first if you could replace the hinge pin and see how that goes.
boler
Help my Perris pacer door doesn't seem to align alan H Problem Solving | Owners Helping Owners 6 02-03-2013 05:28 PM
Align Quick Pomfritz Towing, Hitching, Axles and Running Gear 0 09-11-2012 01:15 PM
17ft Boler 1980 needs a true Boler lover Tina Problem Solving | Owners Helping Owners 5 12-27-2010 10:48 AM
74 Boler Owner NEEDS HELP Jayson Wall General Chat 5 11-10-2009 08:55 PM
74 Boler Owner NEEDS HELP Jayson Wall Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
