EggCamper changes/additions - Fiberglass RV
Old 02-25-2013, 05:26 PM   #1
Trailer: 2015 Escape
After being gone from home for 11 days so far, we've decided that our EggCamper being all electric is not satisfactory. When we get home we'll have a furnace and propane cook top added.
rgrugg is offline   Reply With Quote
Old 02-25-2013, 05:33 PM   #2
Thomas G.'s Avatar
Sounds like a nice addition. Personally, I love propane.
Old 02-26-2013, 05:55 AM   #3
Ron F's Avatar
Trailer: Eggcamper 17 ft Electric
Bob, I added propane to our EggCamper. It's nice to be able to have heat off grid. I didn't bother to add a cooktop. We always cook outside. But, I also replaced the original electric water heater with an Atwood combination electric/propane unit. It means cutting another hole in the side of the camper, but well worth it. I installed it in the same location as the original WH. Two 11# tanks fit nicely in a tongue box.
Ron
Ron F is offline   Reply With Quote
Old 02-26-2013, 08:30 AM   #4
deryk's Avatar
New Jersey
I think its a wise idea. Unfortunatly every time you go out there is no gaurantee that electricity is going to be availible everywhere everytime. Its better to be versatile and prepared.
I wouldn't trade my 3 way fridge for a dc powered one for nothing. Yeah in an ideal world solar will do the job but a few dark and stormy days....nah...I want the 3way fridge manufacturers to start makeing them more efficient so I can run them on solar, and if the weather is gonna be iffy, switch it to propane as a backup plan.
deryk
Old 02-26-2013, 08:34 AM   #5
cpaharley2008's Avatar
I felt the same way with my EggCamper. Do not forget the propane and carbon detectors also. Once you get the propane heat installed you will then feel the need to use the trailer in cold weather and possibly insulate the unit better. That was when I decided to upgrade.
Old 02-26-2013, 09:19 AM   #6
Trailer: 79 scamp 13'
Minnesota
I'm adding a propane furnace to mine as well. My question is with running the lines. Do you have to tee off of the regulator, or can you tee off the main line after it is in the camper? I want as few holes as possible in the floor.
Dan L is offline   Reply With Quote
Old 02-26-2013, 09:42 AM   #7
Thomas G.'s Avatar
You can T off the line any place after the regulator.
Old 02-26-2013, 11:35 AM   #8
Brian B-P's Avatar
I agree that you can add a tee wherever you need, but the fewer fittings and the less line in the interior the better, so tees under the floor with separate lines coming up to each appliance are desirable. I would only tee in the interior for directly adjacent appliances. As with all design decisions, it's a compromise with no single perfect answer.
Previous discussions have dealt with what material is appropriate in each location... I think it's worth searching for those if you have any questions or concerns.
Old 02-26-2013, 12:13 PM   #9
Thomas G.'s Avatar
Originally Posted by Brian B-P View Post
I agree that you can add a tee wherever you need, but the fewer fittings and the less line in the interior the better, so tees under the floor with separate lines coming up to each appliance are desirable........
I agree, better to have fittings outside the trailer.
Adding a hole to the floor is not such a bad thing, especially if you seal the inner perimeter of the hole to protect the plywood.
Old 02-28-2013, 02:31 PM   #10
Trailer: 2009 17 ft Eggcamper / Chevy S-10
If I lived anywhere but in the deep south or it we ever boondocked I would add propane too. Down here all the state parks have electricity! We're staying at a park in Illinois in April and while they have electricity, it looks like they don't have water at every site - the same thing happened the very first night we spent in our EggCamper up in Michigan - electricity but no water! What's up with that?
Ray N is offline   Reply With Quote
Old 02-28-2013, 03:15 PM   #11
mszabo's Avatar
Trailer: U-Haul VT16
It's a lot of work winterizing water lines. And most locations are on wells.
mszabo is offline   Reply With Quote
Old 02-28-2013, 03:51 PM   #12
Thomas G.'s Avatar
Originally Posted by Ray N View Post
.......... the same thing happened the very first night we spent in our EggCamper up in Michigan - electricity but no water! What's up with that?
In Michigan most of us carry packets of dehydrated water.
Old 02-28-2013, 03:56 PM   #13
deryk's Avatar
New Jersey
Ah the good old days!
deryk
Old 02-28-2013, 06:12 PM   #14
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Tom.... I have those dehydrated water packs also. They are so handy you just have to add water and stir. They are great!
kirkman is offline   Reply With Quote
Old 02-28-2013, 06:38 PM   #15
Thomas G.'s Avatar
I started using them when I was backpacking. They save a heck of a lot of weight.
Old 02-28-2013, 06:51 PM   #16
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
You might want to look at the U haul repair manual in the document center. It gives some insight to modifying propane systems as to materials venting etc.
Michael J.
mmeyer is offline   Reply With Quote
eggcamper
Some new additions to the bigfoot Pomfritz Modifications, Alterations and Updates 3 10-19-2012 07:55 PM
A Bunch of Modifications & Additions Jon Vermilye Modifications, Alterations and Updates 5 03-17-2012 05:46 AM
13' Scamp Work in Progress (Lots of Additions) David Morgan Modifications, Alterations and Updates 41 06-04-2010 03:44 PM
Eggcamper Sharon G Care and Feeding of Molded Fiberglass Trailers 30 07-09-2009 03:14 PM
Additions ted saxton Modifications, Alterations and Updates 3 03-03-2008 08:14 PM
