Scamp roof A/C can cause a leak. - Page 2 - Fiberglass RV
Old 10-20-2016, 09:18 PM   #21
Trailer: 2003 16 ft Scamp
Hidden source of a leak
Another "hidden" leak spot to add here. I have a 2003 16' Scamp. Found a rotten spot underneath on curbside rear. On the outside of the Scamp, there's a 110v external 2 socket recep. Flat recep. cover on curved surface of unit. Yep, recep. seal deteriorated and water coming in and puddling on floor behind internal water storage tank. Totally out of sight !!! Would never have known if I'd not inspected carefully from underneath.
Check it out.
jhornsby is offline   Reply With Quote
Old 10-25-2016, 09:07 AM   #22
Trailer: 2014 Scamp 16ft.
Illinois
Yes campers leak. The June 2016 Trailer Life page 52 has a article on roof leaking and a repair that should stop it. The Co. is in Fl.. I feel this system would stop screw leaks in the fiber glass maybe.
Courtland PieperCo is offline   Reply With Quote
Old 06-30-2018, 04:16 PM   #23
Trailer: scamp 13
ME
Thank you so much for this post Gordon. I have a year older Scamp than you but the same AC.
How did you take off the turning switches? I am trying to take off the under cover to tighten the bolts but can't take the switch off...
Do I just pull REALLY hard? I'm afraid I would bust something. There's also a lever that you go up and down do I just yank that off also?
Mine was screwed with 4 screws and the 2 bolt instead of 2 that you mentioned so mine is more prone to leakage I suppose
I just came across this post and when I did a trial run months ago I had a little bit of leakage but I am assuming it's condensation because it is not leaking while rain. I'm covering the tongue and 3 tires but not covering the Scamp itself for now.
amy in maine is offline   Reply With Quote
Old 06-30-2018, 06:57 PM   #24
Trailer: scamp 13
ME
Ok, I went out and it was dangling from 1 switch and the other was on the floor so I yanked it all off lol!!
The front bolts were soooo loose. I tighten it to make it snug.
I only have the feet torque wrench do I need to buy an inch torque?
Would this snug be adequate enough?
Can't believe it was that loose and nothing leaked if I was a little late it may have leaked all over the place
Now I'm scared to screw the screws back in I think I'm going to just put 2 screws in and the 2 bolts just like you so there's 50% chance of drilling it through the fiberglass...
Also, you said your screws were an inch long, mine were 3/4, I wonder if Scamp changed their screws at some point, or they didn't have it nearby and just used the inch screws on yours?? If that's the case I'm thinking that's why some people's Scamps go through and have leaks and some people's don't?
Should I go and get 1/2 inch screws and screw it in instead though? Hmmm...
Old 07-01-2018, 11:09 AM   #25
I guess since most every Scamp has the screws in the ceiling and dont leak, that is an OK way to do it IF YOU ARE CAREFUL. But I have to admit, I like the way I glassed in some wood in the ceiling and screwed into the wood instead of the fiberglass. Of course the VanAir vent in the bathroom still has many screws in the fiberglass ceiling, but they are the area there sealed with Butyl.
Old 07-01-2018, 11:46 AM   #26
Trailer: scamp 13
ME
I would if I was going to keep the AC but I'm still aiming to swap it out to the fan
Although a RV mechanic told me to fill the AC hole and cut out another hole in the front and put the fan there! So it'll be more efficient. I get it, the 2 fans will be too closed to each other but Yeah...NO
Old 05-20-2020, 07:03 PM   #27
Trailer: Escape
United States
Our first trip out with our 16. Ran into heavy rain near Billings. Parked for the night and noticed some drips from the ac. Popped open the air filter and found dampness at one of the screws that is aft. Insulation is wet, looks like water got in between the layers. I’ll study this in detail when we return home.
Rich and Maggie Passmore
2017 Scamp 16
2018 Ford F150 XLT 4WD Supercab
St Paul, MN
rpassmore is offline   Reply With Quote
Old 05-20-2020, 08:26 PM   #28
If you are lucky the bolts are just a little loose and the seal is not sealing. I would snug up the bolts and see if that cures it. If it does not, be advised that it was hard as heck for me to see any evidence of the air distribution box screws going through the shell under the A/C, until I lifted the A/C off the roof a little.
For anyone else.. the bolt(s) are in the metal cross frame in the above photo.. the air box screw in the photo is in the corner of the white plastic.
Old 05-20-2020, 08:47 PM   #29
Trailer: Escape
United States
I read your original post explaining your fix. I’ll start with re-torquing the bolts but I suspect I’ve got the same issue you had. Fortunately I own some Bondo fiberglass resin, so glassing in some small wood blocks isn’t too big a deal for me. I am a bit disappointed by some of the corners they cut, but overall I’m happy with the decision we made. And I’m very grateful for all of you have posted your solutions on line in forums like this.
2017 Scamp 16
St Paul, MN
Old 08-19-2021, 06:45 PM   #30
While this is not a common leak here is another case of exactly the same thing:
https://www.fiberglassrv.com/forums/...air-96635.html
Old 04-15-2024, 10:45 AM   #31
MA
Hi Gordon - I've been reading this most informative post for a few days now, as I am lucky enough to have the issue! Yay me... I've had a leak at just one side vent. I have a 2016 Layout 6. I was hoping that tightening the bolts might stop the leak at the vent. I took the ADB off and saw it was only held by the 2 screws as you mention at the rear vent. I tightened all 4 main bolts and 2 were on the loose side, the others tightened too - going by feel as I do not have a torque tool. Then it rained and I was able to see that yes, that area was still wet at the side vent and also one of the 2 screw holes has water coming in. So I will need to cross this bridge. Ugh.....
My question is about removing those 4 bolts - is it very straight forward to do and then be able to lift the AC from above, or any cautionary tales on doing this? I want to replace that gasket too and would like to know who sells it.
Then I need to consider how to fix the screw hole issue with all the fine input from folks here. No questions about that right now, but I probably will!
Scott D is offline   Reply With Quote
Old 04-15-2024, 12:29 PM   #32
Jon in AZ's Avatar
Originally Posted by Scott D View Post
Hi Gordon - I've been reading this most informative post for a few days now...!
Gordon doesn't check in too often; last visit was a couple of months ago. I noticed that his profile contact page includes a link to send him an e-mail. That might get his attention more quickly. Click on his username or avatar to navigate to his profile page.
Old 04-15-2024, 12:31 PM   #33
MA
Thank you Jon, will do.
Old 04-16-2024, 12:01 PM   #34
Have you had the trailer since 2016? Or for some number of years? If so, then my first thought is that if you never had a leak before then it’s unlikely that a screw penetrated the roof unless you did it when putting the ADB back on, which would be all too easy to do. So, if the leak developed without anyone working on the A/C then I would suspect that the long hold down bolts got loose and/or the gasket wore out.
I was lucky that I did not have to remove the A/C. I only had to lift one side of it. But for gasket replacement you will need to remove the A/C and that’s something I have not done myself.
Of course, you should not get on the roof.. do not expect it to support the weight of a person.
The manual warns that sliding the A/C will damage the gasket, so with the new gasket, it has to be lowered down straight down and into place.. a bit of a challenge I would guess. Perhaps a winch to lower it, or setting up scaffolding support. One or two people on the outside and one inside. The one inside can guide it in place as its lowered and lift up a little if needed.
Just maybe you could use a floor jack / screw jack to lift the A/C a few inches to get a new gasket on. Might have to put the jack through the middle of the gasket, lift the A/C with someone outside to keep it balanced, and work the gasket up and through the hole (inside the camper). Then get it in place and lower the A/C. Also, use a board or something to distribute the jack support area in a way that does not damage the A/C. BUT FAIR WARNING… this is just something I thought of this minute and no idea if its practical. I would look at it carefully before considering that approach.
However you do it, with the A/C off the roof you can inspect the roof for screw holes. Even with the A/C in place you might be able to see a screw protruding by shining a flashlight in the gap between the roof and the A/C (at night or a dark day). You could lift the A/C to get a better look but then you take a chance of damaging the gasket, so you might be better off doing a full gasket replacement (esp. aft 7-8 years).
Personally, I would probably go to a shop when they have the tools and experience, but make sure they know not to put their weight on the roof. If its Dometic, their website list service centers... but one is Camping World and too many unhappy customers there for me to use them.
For the gasket, it looks like there are lots of suppliers online… some are generic and some OEM. IDK if that matters. I wonder if Scamp sells parts for 2016 model A/Cs.
Hope that helps some.
Old 04-17-2024, 07:57 AM   #35
MA
Thank you Gordon, good advice all around. I bought this in OCT '23 and discovered the leaks. Been tarping it until fix is done.
Daisy went on to help fight a cause...Happy scamp story Flygal General Chat 14 08-09-2013 01:43 PM
Whats fuel costs gonna cause? Bruce Thomas General Chat 37 03-02-2011 12:18 AM
What Could Cause a Hot Wheel Hub? Anne Badgley Problem Solving | Owners Helping Owners 9 11-17-2009 02:55 PM
