11-27-2016, 09:52 PM
Trailer: 1975 Trillium 13 ft
What type of tow vehicle for Scamp 5th with 3" factory lift?
We are considering a Scamp 5th wheel. I have seen a few Chevy Colorados but does it make a difference with the 3 inch lift? The current owner drives a Tundra.
11-28-2016, 05:55 AM
Illinois
lift kit
The 3" lift kit raises the trailer, this allows for more clearance over the bed sides of the truck. It also may require adjusting the hitch higher to level out the trailer. Over the last few years, full sized pick-ups have become taller, especially the four wheel drive models. The lift kits for the 5ers give you more choices for tow vehicles.
BobH.
11-28-2016, 06:44 AM
Based on the new-design Colorado trucks I've seen, I'd guess they require the 3" lift. They're pretty tall.
But instead of guessing, why don't you call Scamp? Ask for the bed rail height range with and without the lift. Then take a tape measure with you when you shop for a truck.
11-28-2016, 06:48 AM
Thank you both. We will call Scamp today.
11-28-2016, 06:57 AM
Trailer: 16 ft U-Haul VT
If you go this route for purchase, you might wish to look into this posting: http://www.fiberglassrv.com/forums/f...tml#post618164
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
11-28-2016, 09:37 AM
Iowa
Hi Kristi,
We have had our 19 for about a year and one-half and have enjoyed it greatly. We currently pull it with a 1994 Silverado, which works great.
We are looking to upgrade to a new(er) truck and I would be most interested to know what measurements Scamp provides you with for clearing the side rails. We've done a little bit of shopping for a truck and the new(er) ones certainly do seem to be too high for pulling our fiver.
Peter
11-28-2016, 09:56 AM
NW Wisconsin
Why don't you take measurements of the current owners vehicle ( Bed sides and trailer clearance ) . That should help you determine which vehicles will work with a Scamp 19 5th wheel.
Buying a vehicle based on a guess and then having to make modifications to both the vehicle and the trailer seems rather foolish IMHO
11-28-2016, 12:03 PM
Kristi, I hope you find a Scamp 19 to look at. Mine has the 3" lift and I tow it with 2013 Tacoma, 6cyl. The "smaller" trucks are not that small any more, so the Scamp lift might become the standard one day, I expect. The Tacoma is a great TV and the Canyon or Colorado should be good match for the Scamp 19 as well.
Scamp will give you the dimensions you need - the height of the bed, the sides and distance from the ball to the truck corner. My User's Manual says 60 in. ball to corner and the rest describes the old style hitch. I installed the new one myself.
11-28-2016, 01:53 PM
Trailer: Scamp 19'
Wyoming
Scamp 19 and 2016 ram eco diesel
When I bought my scamp over a year ago, I had a Ford Ranger. Though it pulled it, when heading into headwinds like we have in Wyoming, she just couldn't muster. We went in search of a new TV and found the Ram Eco Diesel and had to adjust my hitch all the way down and was concerned about clearance. But when all said and done, the Scamp fit just fine with the 3" lift and then later I changed the tires from 14" to 15". Have had no problems and now I only know the Scamp is behind me when I look in the mirrror. Not to mention that we get 18-20 MPG. See picture attached. This is with the 14" wheels and tires.
P.S. This is the 4 Wheel Drive Model. Needed in Wyoming.
11-28-2016, 02:20 PM
SW Florida
Are you sure you changed tires from 14 to 15"? Original Scamp's tires are 13".
Sergey
11-28-2016, 02:33 PM
Trailer: Scamp 19'
Wyoming
I guess you have not checked with Scamp or on their web site lately. The 19' comes with 14" tires and we did our homework before buying so that in the future if needed we would have options for a different tow vehicle. That also narrowed down the field for full size trucks for a new tow vehicle. But the Ram Eco Diesel in 4WD fits well under our 2015 Scamp 19" with 3" lift and 14" wheels that have been changed to 15" wheels. Scamp is always changing as other manufacturers do to keep up with the industry and customers requests. We also had a some modifications done and extra goodies added. That is the nice thing with a manufacturer such as Scamp so you get what you want instead of settling for what's on the lot.
Take a look at the Scamp web site and see the changes and improvements they have made. I'm sure you will be impressed.
11-29-2016, 11:56 AM
Minnesota
For the 19', 14" wheels were a factory option.
2021 Nissan Pro 4X. 2020 Scamp 19’ Deluxe.
11-29-2016, 12:49 PM
Trailer: Scamp 19'
Wyoming
This is from Scamps website. I was never offered an option, just came with 14" tires standard.
Years ago that was probably the case. Now the come standard with 14". I would highly recommend upgrading to at least 14" wheels and even 15" wheels as it stabilizes the load better and gives you a better load range.
11-29-2016, 02:49 PM
SW Florida
Will 14" (or 15) wheels fit 16' scamp without lift kit?
Sergey
11-29-2016, 03:27 PM
Minnesota
My Scamp is a 1999. Then I believe that 13's were standard. Things inevitably change in 17 years!
My Scamp has 14" and I have considered upgrading to 15's.
11-29-2016, 03:36 PM
Trailer: Scamp 19'
Wyoming
I think you would need to get the measurements of a 14" or 15" tire you plan to use and then measure your wheel well to determine if you have the clearance. That is what I did and found to have enough room. With out the lift, it may be tricky.
I took the existing 14" wheel and tire, measured it and then got the measurements of the tire and wheel I wanted to put on and then measured from the center of the hub with a string in an arc to see how much clearance I had and figuring the travel distance up and down to make sure I had enough room. Try this and it should give you a good idea if it will work or not.
I wanted to go with 16" tires but had the 15"s so that is what I worked with.
It only added about 3/4" to the height difference but every little bit helps. Maybe when I wear out the 15"s, I will go with 16"s.
11-29-2016, 09:07 PM
Originally Posted by Peter S. in Iowa
Hi Kristi,
Peter
My husband called Scamp. According to Scamp only 3 trucks will not work: Chevy Avalanche, Honda Ridgeline and a Ford truck that I can't remember. They also said that as long as the height from ground to the top of the truck side does not exceed 58" it will work.
11-29-2016, 10:48 PM
Trailer: Scamp 19'
Wyoming
Good to know. The small trucks do ok but we were looking for a little more hp and better mileage. We did take a tape measure with us and had the requirements needed for hitch and trailer. Had my heart set on a Toyota Tacoma but found the ECO diesel in a full size new for less than the Toyota and ended up with more power, more room and better mileage. In my opinion a diesel is the only way to go but then some people just don't like them. The bed of my Dodge Ram 1500 4X4 is about 56". Happy hunting for your new TV.
11-30-2016, 07:06 AM
Trailer: Trillium 2010
..... and a Ford truck that I can't remember.
Ford Explorer Sport Trac perhaps?
10-01-2018, 11:30 AM
Hello jfleming,
I'm about to purchase a Scamp 19 and have realized I'll have some clearance issues with truck (a 2015 Ram 1500 ED 4x4) with the Scamp in stock form. It would appear that you have it all figured out with your ED. Would you mind if picked your brain about your trailer/hitch set-up?
