1979 Trillium Restoration by The Egg Plant - Page 2 - Fiberglass RV
Old 09-07-2014, 08:38 PM   #21
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
With the converter installed, I could run all of my interior electrical needs — 12VDC LED lighting, a USB port and a few 110VAC plugs.
Robert Johans is offline   Reply With Quote
Old 09-07-2014, 09:04 PM   #22
Hello Jim,
About the storage box: I've had in around for a while, waiting for the right application. They're referred to as a "triangle trailer storage box" and I believe the manufacturer is "DeeZee."
This trailer does have a rock guard for the front window, though it's hardly water-tight.
Frankly, because the propane regulator has a defined inlet and outlet, and a vent that points down, there's only one way to mount it — to the outside of the street-side rail, as shown. To be honest, I hadn't thought about potential damage there. Maybe I should!
Old 09-08-2014, 11:06 AM   #23
David Tilston's Avatar
Very nice!
I am kinda surprised that you brought the emergency break away, and the brake controller wiring in the side. Trillium used a hole in the bottom of the trailer, which makes sense to me, in terms of leak potential.
What are you going to do with the furnace?
Old 09-09-2014, 09:11 PM   #24
I use secure fittings to keep water out. We've replaced the old, broken furnace with a Wave 3 radiant heater.
Old 09-10-2014, 05:40 AM   #25
cpaharley2008's Avatar
As always Robert, a detailed exceptional job conclusion. Great work. How is Nest coming along?
Jim
Never in doubt, often wrong
Old 09-10-2014, 08:39 AM   #26
Are you aware that original Bargman tail lights are available from this website?:
Fibreglass RV Parts, Repairs, and Service by Paul Neumeister
Old 09-10-2014, 08:43 AM   #27
Trailer: Scamp 13
Very nice well thought plan of action. Good job the owner will be impressed.
Old 09-10-2014, 09:58 AM   #28
Clayton's Avatar
Trailer: 1975 Trillium
Hey Robert, nice job. How did you mount the Wave 3 heater? I'm very interested in them.
Clayton is offline   Reply With Quote
Old 09-10-2014, 01:46 PM   #29
Hello Jim (CPAHarley). Thanks for asking about the Nest. Tooling for the shell parts is finally nearing completion. Prototypes to roll early next month. I've been able to update the Nest thread with some recent developments.
(http://www.fiberglassrv.com/forums/f...tep-63317.html)
David, as far as I know, the original Bargman are not LED — a requirement from the client.
Steve, thanks for your note.
Clayton, the client and I are considering a couple options with the Wave 3: a "permanent" install under the front dinette table; or a "portable" — pull out of storage when needed — with a gas quick-connect fitting.
Old 09-10-2014, 07:49 PM   #30
Roy in TO's Avatar
Robert, a number of us have taken the "guts" out of a submersible LED set available at Harbor Freight, Princess Auto and a number of other places - then MacGuyvered them into the original housings.
I think Randy Bishop was the first to post how to do it here:
http://www.fiberglassrv.com/forums/f...tml#post270659
Others have added a second small round LED to completely fill the original housing.
Old 09-10-2014, 07:58 PM   #31
DBH
Trailer: '76 Trillium
Absolutely beautiful work. Look forward to seeing the finished pics!!
DBH is offline   Reply With Quote
Old 09-11-2014, 02:35 PM   #32
Hello Roy,
Yes, I too considered, and offered the Randy Bishop custom taillight option to my client, but she passed, opting for the off-the-shelf alternative you see.
Old 09-11-2014, 04:12 PM   #33
Roy in TO's Avatar
Thanks Robert,
I scrolled back to see what you did. Interesting that the lights you used appear to be the same ones Randy suggested will fit into the original housings. Oh well, it is not our trailer.
Old 09-16-2014, 08:51 AM   #34
I don't know Roy. I think I can see the individual LED's. One in the outside section and eight in the middle section. They look different then the ones we used.
Old 09-16-2014, 09:51 AM   #35
Clayton's Avatar
Good eye David. I think you are correct. I also added a small round 6 node LED to mine.
Old 01-04-2015, 09:25 PM   #36
Trailer: 1979 Trillium Jubilee
A couple years ago, we made some repairs to a leaky front window on this Trillium. Now it's back because the rear windows are shot too...
The Trillium window is mounted through its aluminum frame with screws that twist into inner frames made of plywood. Over time, the window pulls away from the FG shell body allowing water to seep in, which in turn saturates the plywood.
This wet wood rots over time and causes the screws to rust, which further weakens the window seal.
The only appropriate repair is to remove the old, rotten wood and glass in replacements. But instead of plywood, we will use a product called NyloBoard — a resin/wood composite material that is impervious to rot. And unlike something akin to "Trex", NyloBoard has terrific strength holding screws.
How does the Nyloboard hold up to vibration since it is a composite material?
tbclinton is offline   Reply With Quote
trillium
72 Trail Mite — Rebuild by The Egg Plant Robert Johans Modifications, Alterations and Updates 51 11-26-2021 05:22 PM
77 Boler 13 Restoration - Our first Egg DaveWhit Modifications, Alterations and Updates 20 10-06-2015 10:19 PM
Boler Rebuild by The Egg Plant Robert Johans Modifications, Alterations and Updates 13 06-06-2014 10:16 AM
Egg plant carlkeigley General Chat 8 08-05-2013 05:08 PM
Snoozy Plant Update melissab General Chat 1 05-10-2011 07:36 PM
