New Heater for our Trillium 1300 - Fiberglass RV
Old 11-05-2014, 10:43 AM   #1
Clayton's Avatar
Trailer: 1975 Trillium
So after our first full season of camping with our '75 Trillium 1300, we have found that the appliance that we used the most was the furnace. It is still the original DuoTherm that was stock in the trailer. We actually used the furnace every time we had the trailer out this summer! I am thinking (but have not fully decided) of upgrading it to a new unit but unsure what is the best way to go. Any advice is appreciated....
Clayton is offline   Reply With Quote
Old 11-05-2014, 11:29 AM   #2
David Tilston's Avatar
I will gladly buy your existing heater.
The options available are all forced air furnaces. They have to go under a dinette seat, since they are much longer then a gravity furnace. This means that you will have to cover up the hole where the Duo-Therm vent is now, and cut a new, (much smaller) vent for the replacement.
Why do you want a new unit? Is there something wrong with the existing Duo-Therm?
Old 11-05-2014, 10:03 PM   #3
Clayton's Avatar
Hey David,
I haven't fully decided if I am going to replace it. The reason I am considering it is to get a new unit that is a bit more efficient and slightly higher BTU. There is nothing wrong with the existing Duo Therm unit. I actually sandblasted and re-painted the interior grill with high heat paint.
Old 11-05-2014, 10:36 PM   #4
John Linck's Avatar
Trailer: 1990 Scamp 16 ft
I would like to be next in line to purchase. I hate the noise and battery draw of my furnace. A bit extra propane consumption would be well worth it.
John
John Michael Linck - Toymaker
Camping since 1960 - Scamp 13' Oak
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 11-06-2014, 12:44 AM   #5
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
I just installed a furnace into my non heated casita and wanted to use the newer Atwood Furnace
Atwood 8012-II 36551 12K BTU RV Trailer Furnace 8012 Hydro Flame Camper Trailer RV
which is much quieter than the suburban furnace used in casita's but the Atwood required 11-3/8" height clearance and i only had 9-1/2" height where i needed to install so i had to go with the noisy suburban which fit that area.
Maybe this will help you in some way as i am not familiar with your trailer
Joe Z is offline   Reply With Quote
Old 11-06-2014, 07:48 PM   #6
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
Might end up with a bidding war!
Old 11-07-2014, 11:03 AM   #7
Clayton,
There is a fan unit that was meant for your furnace:
http://www.fiberglassrv.com/forums/f...wer-54226.html
But I think a peltier fan might also help:
Ecofan Gold Airmax | Canadian Tire
Either of these should help produce more heat.
Old 11-07-2014, 08:43 PM   #8
Clayton's Avatar
Thanks for the info David. I think I might give the Ecofan Gold Airmax a try.
Old 11-07-2014, 11:15 PM   #9
Joe Z's Avatar
I thought that ecofan was interesting so i asked the owner of the site on amazon if it would work in front of a Wave3 Catalytic heater and he said "No" that the heat must be at the base only and the difference of the heat between the base and the top is what makes the fan spin...... I really wanted that to work for my situation
this was the link to my question
Amazon.com: Questions And Answers: Would this work in front of a wave3 Catalytic Heater as long as the temp is below 650 degrees?_____ Would the blades melt?_____
Old 11-08-2014, 01:25 AM   #10
Roger C H's Avatar
Smile Our Heater
Our heater has no red-hot coils nor noisy fan:
Name:	Feature Comfort.jpg
Of course one does need electricity.
Old 11-08-2014, 01:31 AM   #11
Joe Z's Avatar
We had one of those in a small bathroom and they are the best because they hold the heat after they go off. I should try one in the camper as they make no noise and heat very well.... Almost reminds me of the steam radiators as a kid
Old 11-08-2014, 01:36 PM   #12
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
Not only is it quieter, but it also has the lowest current draw of any forced air furnace - 1.8 amps compared to over 3 for most. I have one in my Escape 17, and it does the job.
Old 11-08-2014, 05:17 PM   #13
Joe Z's Avatar
I agree with you on the lower amp draw but didn't know exactly what it was.
My friend has an Atwood in his 17' Escape...... Sure wish i could have fit it in the Casita
Old 11-10-2014, 10:34 AM   #14
Your answer has been removed. I think it would work fine, depending on the install. Francesca uses something similar:
http://www.fiberglassrv.com/forums/f...tml#post237766
http://www.fiberglassrv.com/forums/f...tml#post247447
Old 11-10-2014, 10:42 AM   #15
Joe Z's Avatar
It's my own fault it was removed. I had so many people responding back to me with a no it won't work like that answer that i withdrew the question to stop so many amazon emails back.
If you try it let me know if it works for you
I do have to admit your second link "vented cat heater" with the shroud over it and just heating the bottom of the fan is a very good idea
Old 11-10-2014, 11:03 AM   #16
Clayton's Avatar
I do like the Duo-Therm that is currently in the trailer but I do want to try and move the warm air around. I might even try a small "clip on" electric fan with low power draw........although it does kind of defeat the purpose of the furnace not having to use any power
Old 11-10-2014, 01:28 PM   #17
Jim Bennett's Avatar
This would be a deal breaker for most of us. I do carry a small cube heater, should I ever be connected, but it rarely sees any use.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 11-10-2014, 02:49 PM   #18
Clayton's Avatar
I hear you Jim. One of the reasons I love my Trillium so much is the simplicity and the ability to be "off the grid".
Old 11-10-2014, 04:30 PM   #19
I use the incinerator, on the furnace, when it gets cold:
http://www.fiberglassrv.com/forums/f...one-57925.html
Old 11-10-2014, 04:42 PM   #20
Clayton's Avatar
LOL, that's awesome!!!
trillium
Inside our 1975 Trillium 1300 - cupboards aubrey johnson Modifications, Alterations and Updates 10 07-11-2016 08:52 PM
CANADA - Trillium 1300 - $1300 David Tilston Referrals: Molded Fiberglass Trailers 2 01-26-2016 01:34 PM
ME | Sold ~ Selling Our Beloved 1977 Trillium 1300 OurPalsMom Classified Archives 3 04-19-2014 01:44 PM
Our 1st Trillium 1300 Ted Hi, I am.... 19 09-24-2012 06:18 AM
Our new/old 1976 Trillium 1300 bklunder Hi, I am.... 2 08-28-2012 07:44 PM
