trillium table? - Page 2 - Fiberglass RV
Old 11-14-2014, 09:08 PM   #21
Trailer: 77 trillium 4500
Hi david just a thought do you have any idea how much space is between the top layer of the fiberglass floor and the bottom layer? It must be more then the thickness of the plywood? I wonder if there are ribs like a boat? Any idea? Has anyone have pics between the two layers of fiberglass? www.transomrepair.net - The Home of Seacast™ - www.transomrepair.net - The Home of Seacast™ This is why I ask.
bc-aaron is offline   Reply With Quote
Old 11-15-2014, 01:12 PM   #22
Roy in TO's Avatar
Arron, your boat link got me to thinking and searching.
Check out this link Wood preservation, rot repair, and restoration using epoxy resin on boats, homes and log homes.
and scroll down to Repairing Rotted Cores Method 2: Treating Core Without Removing Fiberglass Skin.
The skill saw technique sounds interesting. I'd be tempted to try it by making a few widely spaced cuts, using the material and letting it set. Then repeating with cuts between the initial ones or even in a checkerboard pattern.
It appears that they are using this stuff CPES
Clear Penetrating Epoxy Sealer
Old 11-15-2014, 04:07 PM   #23
Hi Roy
This is pretty interesting stuff the only wonder is any after smell in the enclosed trailer? I take it we are in the same boat "trailer". I was just looking under the front couch and pulled up some sort of flooring the PO laid down on the floor under there and the wood is so bad I was pulling chunks of it up with my hands right down to the lower fiberglass shell? I stopped right away but when I have more time Ill see how much comes out.
Old 11-16-2014, 03:01 PM   #24
David Tilston's Avatar
I am fairly sure the plywood is tightly sandwiched between the outside shell, and the inside floor of the trailer. This picture is of my trailer that I call the Cantaloupe. It has been my experimental trailer. I tried out my belly band technique on it first:
http://www.fiberglassrv.com/forums/f...ead-58763.html
I have looked very closely at it. This picture is shot looking straight towards the back of the trailer. The camera is almost on the floor looking inside the kitchen. In the early trailers, the furniture was one piece. From the back, I can look forward, into the kitchen.
This is different in a 4500. The gaucho is it's own piece, and doesn't connect to the kitchen. But I suspect that they do the plywood in the floor the same. It might actually go right to the side of the trailer, like the later years did in the rear dinette bins. You can't see the bottom of the pontoons, that run down the outside of the frame. Since the sheet they were working with is 8' long, the could have run it right to the wall.
Old 11-16-2014, 05:11 PM   #25
A few more pictures of that plywood, from different angles.
Old 11-18-2014, 06:15 PM   #26
Trailer: In the market
Manitoba
I saw a Trill with an original cutlery drawer still in place. I'm a newbie too
Susan
Dustmote is offline   Reply With Quote
Old 11-19-2014, 06:33 PM   #27
Trailer: Trillium
Saskatchewan
Our Trillium has a sliding cutlery box holder under the table. It even has a wee locking gadget to keep it in place.
Hazel in Sk is offline   Reply With Quote
Old 11-21-2014, 07:53 PM   #28
Jane in California's Avatar
Trailer: Trillium
I have a place for a drawer too! I am bemoaning the fact that there is no "fabricator" in my life! My hubby can paint, but otherwise I'm on my own!! I will take measurements and look around in the thrift stores and so on. Since my dinette will be up most of the time, I look forward to this extra storage space!
Jane in California is offline   Reply With Quote
Old 12-18-2014, 08:49 PM   #29
Hi Dave, could you please tell me where I would look to find the serial number on my Trillium. It is a 13 ' 4500 model.
Cheers
Ozzyjude is offline   Reply With Quote
Old 12-19-2014, 06:57 AM   #30
Jim Bennett's Avatar
Cheers
On my 1300 it is on the inside of the closet door.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 12-19-2014, 10:01 AM   #31
Since yours is a 4500, the only place I have seen it is in the upper right corner of the data sheet on the inside of the closet door, like Jim said.
Some 1300's have a tag just outside the entry door.
Old 12-19-2014, 07:17 PM   #32
Thank you, I will check the next time I am out at the property.
Cheers,
Judy
trillium
Want to improve my table in Trillium 1300 Darren Pettis Problem Solving | Owners Helping Owners 13 10-12-2009 08:56 AM
Trillium 1300 - Information on shelf over dining table Booker B. Problem Solving | Owners Helping Owners 12 04-20-2008 09:54 PM
Wanted: Trillium Dining Table hardware Booker B. Classified Archives 4 03-25-2008 02:36 PM
1978 Trillium Side Table Question Daisy Problem Solving | Owners Helping Owners 1 05-17-2006 04:55 PM
