79 trillium 4500 'bucking' - Fiberglass RV
Old 12-15-2014, 09:07 PM   #1
Hi! I'm a newbie and just got my first trillium. On our drive home, it was 'bucking' at the hitch. We are driving a 2011 Jeep Liberty. It feels like it's going to fly off the ball. Added some weight to the front of the trailer. Helped a little. Any other recommendations? Leaving for a 4 month trip, next week.
gomerthetrillium is offline   Reply With Quote
Old 12-15-2014, 09:42 PM   #2
Trailer: Trillium 1974
Quebec
Same problem for me last summer for my 1974 Trillium 1300 ...it was a frame problem ...may be not, for you.
Near the front mounting bolts.
Lots of bounce on the Hitch.
Inspect your frame.
May be it s another problem...
DanSpeed is offline   Reply With Quote
Old 12-15-2014, 10:10 PM   #3
Borrego Dave's Avatar
Welcome to FGRV. You may have a frame crack as was noted but most bucking I've heard of is caused by a poorly loaded trailer. Is your trailer when hitched up and on level ground sitting level or a bit nose down ? You never want to have the nose up. You may have to change out the stinger to get the right height. Having the correct tongue wt is very important for a smooth tow, generally 10 -15% is what's called for. Also, is the ball size correct for the coupler or maybe the coupler may need to be tightened up a bit.
Others will be along soon with more for you.
Old 12-15-2014, 10:55 PM   #4
WildBirder's Avatar
Trailer: 1969 Boler (Flat Top)
I experienced the same thing on my first tow. The coupler needed to be loosened so the ball could be set inside properly. I then retightened the coupler.
It's a learning curve. These trailers tow pretty smooth. If it doesn't seem right, it probably isn't.
Take short test drives, pull over if there's an issue.
Oh yeah.. and welcome to the forum!
Lots of good advise here.
Mark
1969 Boler
(#183)
WildBirder is offline   Reply With Quote
Old 12-16-2014, 09:26 AM   #5
Martins HeirCon's Avatar
Trailer: Trillium 1300
Georgia
Hi, bamtech1 from IG. Glad you made it here!
I didn't even question ball size and coupler adjustment, more things to look at. If you can't find the answer here, I don't know where!
Martins HeirCon is offline   Reply With Quote
Old 12-16-2014, 10:28 AM   #6
David Tilston's Avatar
I think that by the time they made the 4500's, they were putting the reinforcement plates on all trailers, so hopefully a cracked frame is not the problem.
I also suspect poor loading. Your tongue weight should be at least 200 lbs.
Old 12-17-2014, 10:39 AM   #7
Trailer: 77' Trillium
bucking
we have had experience with a Trillium 13' and a 4500. The 4500 always bucked no matter whether we loaded heavy in the front or what. We had none of those problems with our 13'. smooth ride all the way.
It seemed to us that they used the same frame for the 4500 as the 13' and it just made for a bucking good time! If the tongue was lengthened by 12" and the spare put on the front with the battery and tanks the tongue weight would be better. I really like the inside finish of the Trilliums over the other small fiberglass trailers.
Nadine Y. is offline   Reply With Quote
Old 12-17-2014, 11:23 AM   #8
Trailer: Shopping for new RV
No one has asked if you have a weight distribution system for your rig.
If not get one....if you do have one then check adjustments on that.
New trailer plus new tow equals some trial and error adjustments.
Try all suggestions and inspections until you correct the issue....then...
Happy Camping!
Uplander is offline   Reply With Quote
Old 12-17-2014, 11:38 AM   #9
Trillium recommends NOT using a weight distribution hitch. Apparently the frame is not strong enough.
Old 12-17-2014, 05:30 PM   #10
Roy in TO's Avatar
You can also check the axle to make sure it still has spring and shock capabilities left in the rubber. A torsion axle has no torsion properties if it is frozen.
Old 12-18-2014, 04:28 PM   #11
Larry Tenhage's Avatar
Name: Larry & Joyce
Trailer: 1974 Trillium 1300
Fergus Ontario
In addition to the frame / weight distribution problem, if the trailer tire pressure is too low / uneven, you could get swaying / other problems too.
Larry Tenhage is offline   Reply With Quote
Old 12-18-2014, 04:39 PM   #12
Paul O.'s Avatar
Another cause of "bucking" could be tire pressure too low. I would make sure it is what the plate with the VIN says it should be, or to the max allowed for the tires you have. When I towed my (used) Scamp home the very first time, the tires were only 30psi and it was rough. Much better when I inflated them to what they should have been (45psi). I was a newbie, learning from scratch.
Forget about the weight distribution hitch, until you get more information.
Old 12-18-2014, 08:13 PM   #13
Virginia
my egg bucked the whole way home when I bought it. I got so scared I pulled over & did a walk-around to see what was wrong! filled it & the truck up with groceries & gear, took it on the first trip - it was a completely different animal. I hope your luck is same as mine!
sharon_b is offline   Reply With Quote
Old 12-19-2014, 06:01 AM   #14
I'm with Roy on this one. The difference between a worn out axle and a new axle on my Scamp was huge.. absolutely huge! If you try all the other suggestions from forum members and don't find a complete resolution, a new axle may be the solution.
Be safe
Old 12-19-2014, 04:10 PM   #15
What about coupler?
Thanks all! I'm trying a bunch of these solutions. Will report back.
Also, the coupler is the original and is rusty and loose. I assume it should be a little loose so it can lock into place. But should I get that replaced? Could that cause this?
Steven
Old 12-19-2014, 04:57 PM   #16
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
Once it's locked onto the ball, it shouldn't be loose. There may be an adjustment on it. If not (or if it's too rusty to budge), a new one may be best.
Old 12-19-2014, 05:28 PM   #17
MC1
MC1's Avatar
I'm with Mike. Once you lock that coupler down it should be snug with no play.
MC1 is offline   Reply With Quote
Old 12-22-2014, 11:25 AM   #18
Well, there often is some play between the receiver and the stinger. Which you can buy a clamp for.
Old 12-22-2014, 11:38 AM   #19
Georgia
...but all of those are symptoms, not the cause. Any setup will rattle a little when unweighted, such as over bumps. Get it level and weight biased to the front first.
Old 12-22-2014, 04:33 PM   #20
Name: Larry & Joyce
Fergus Ontario
Is it possible that you're hooking up a 1 7/8" ball to a 2" receiver? I.E, is there too much play in the hitch? That would cause some rattling if not outright causing the trailer to detach itself.
trillium
Scamp 5th wheel "bucking" on uneven surface ? Westcliffe01 Towing, Hitching, Axles and Running Gear 15 11-12-2013 11:29 PM
CA | For Sale: Trillium 4500, Santa Barbara. $4500 SOLD! tellis Classified Archives 7 09-04-2013 11:07 AM
AB (Canada) - Trillium 4500 - 1978 - $4500 David Tilston Referrals: Molded Fiberglass Trailers 16 04-22-2013 01:07 PM
"Bucking" feeling while towing in-town (trillium 1300/volvo 245) coalminecanary Towing, Hitching, Axles and Running Gear 12 10-18-2011 11:59 AM
1979 Trillium 4500 for sale -- C$5200 or US$4500 - SOLD jenniferm Classified Archives 8 07-14-2009 01:38 PM
