Flooring ? - Fiberglass RV
Old 05-21-2018, 07:19 AM   #1
mensie's Avatar
Flooring ?
Earlier this spring I got me an 1977 Trillium 1300 it does need work as it sat in the field for a number of years. It has nasty carped on the floor what do most of you put on the floor? laminate , Lino I don't want carped something easy that can be swept out.
Old 05-21-2018, 08:30 AM   #2
None
I pulled the carpet from my '99 Scamp and replaced it with the adhesive strip Allure from Home Depot. Has been in for a couple of years now with no problems. Michigan Winters, then down to Florida for part of winter Just make sure you allow it to "float" as it was designed.
The hardest part of the project was getting the carpet and glue off. The Allure must be placed on a smooth surface. Installing the Allure is quite simple once you do a few planks.
An added benefit of this project was that it allowed me to do a close inspection of the entire floor. I found small areas of "soft" wood from a prior water leak at the door. Prior to installing the Allure, I was able to replace a small section of the floor at the door, to make a proper repair. I now have total confidence that my floor is in great shape, and will not be a problem for many years to come. Replacing this section of floor would be simple for someone with good carpentry/building skills, for me it was a moderately daunting project, but doable by taking my time and thinking it through. Turned out well.
LyleB is offline   Reply With Quote
Old 11-21-2018, 04:20 PM   #3
Trailer: 1975 Triple E Surfside
I use good lino... and even though they say don't use contact cement.. I did. go wall to wall.. right under everything.. silicone the seams.. this keep all and any moisture out.
Retired and love new projects.. and blog about them
https://www.robeye.ca
robeye is offline   Reply With Quote
Old 11-21-2018, 04:41 PM   #4
Endless threads on flooring, I put Shaw click vinyl flooring on my 1977 Trillium.
Old 11-21-2018, 08:57 PM   #5
MyronL's Avatar
Trailer: Escape
New Mexico
The hard lesson I learned about installing wood flooring is it looks absolutely gorgeous, but in the boonies (or anywhere really), you risk tracking in grit, gravel, dirt and that scratches and scuffs it big time.
MyronL is offline   Reply With Quote
trillium
Flooring Karen Fisch Problem Solving | Owners Helping Owners 29 03-26-2006 09:50 PM
Flooring: Interlocking PVC Floor Tiles? S Sato Modifications, Alterations and Updates 5 03-13-2006 02:07 PM
Flooring Legacy Posts Modifications, Alterations and Updates 59 01-28-2006 08:15 AM
Flooring removal Legacy Posts Problem Solving | Owners Helping Owners 1 06-01-2003 07:40 PM
trailer flooring and insulation General Chat 0 01-01-1970 12:00 AM
