Trillium axle finally installed! - Fiberglass RV
Old 12-23-2018, 03:45 PM   #1
Trailer: Trillium
Hi Folks,
Thanks to all those that offered advice, I ended up having the new Flexiride axle put on without having to remove the shell from the frame. I went w/ the Flexiride adjustable as many of you suggested, starting at 22 degrees down and I've got plenty of clearance and options to dial it in. I also had the optional side mount brackets welded to the frame and bolted my axle to them. I am going w/ a bigger and taller tire ST205/75R14, sits nice behind my 4 runner.
Will fly up some photos soon. Will be heading south along the I75 in the next few days, cheers and happy holidays!
Jorge from T.O. is offline   Reply With Quote
Old 12-23-2018, 06:11 PM   #2
Trailer: Sold it
Northern VA
Sounds good. I'm looking to do some work on my Burro and been leaning towards the Flexiride axle. Also looking to replace the frame.
Sold the burro
Old 12-23-2018, 09:29 PM   #3
I just put 205/14s on my 1977 Trillium 1300 myself. Since the axle is original, figured a new one would be coming in the near future.
Old 12-23-2018, 09:30 PM   #4
Trailer: Trillium
Photos of new axle on the Trillium.
Here's a few shots of the new axle and tire clearance, cheers, Jorge.
Old 12-29-2018, 03:27 PM   #5
Where do you get the flexride and what spec's for a Trillium 4500?
drd715 is offline   Reply With Quote
Old 01-27-2019, 02:23 PM   #6
Trailer: Trillium
I got the axle from CERCA in Ontario, Canada, my trailer is a 1300 so I don't have the specs for a 4500, you should probably have it measured regardless.
Here's a link to Cerca/Flexiride, FLEXIRIDE AXLE
I got the #7 2200lbs w/ electric brakes.
Just did 5000kms to Florida and back, worked perfectly, cheers, Jorge.
axle, trillium
Finally, Finally... Richard Hayes Hi, I am.... 11 06-16-2012 09:35 PM
Installed Axle cost Vancouver, Canada rhkirkham Towing, Hitching, Axles and Running Gear 24 05-26-2011 12:58 PM
Finally Installed a Fantastic Fan Carol H Modifications, Alterations and Updates 4 05-01-2009 11:37 AM
Finally the new axle is installed! mcnick Modifications, Alterations and Updates 30 05-22-2008 09:58 PM
Finally got a Scamp! Axle/suspension perhaps needs work HustonFamily Towing, Hitching, Axles and Running Gear 27 04-06-2008 01:22 PM
