I have started rebuilding a 1990 Freedom Deluxe. Everything is stripped out to the
fiberglass skin... A bigger project than I first thought... Working on identifying pieces and parts to put it back together. I cannot find the toilet with it's integrated tank... Dometic has a SeaLand 711-M28 Toilet but looks like it does not have that bottom dump fitting. The old SeaLand 911 model tank is a two part tank, has been repaired once and is probably not a good bet for repair and the valve assembly parts cost about half what an entire unit is priced.
Anyone know where I can get a similar integrated toilet and tank? I have sent a request to
Casita but so far no answer.
I am also looking for door hinges and latch hardware for the older model curved door.
And third, I am planning on using aluminized on both sides "prodex" 2mm insulation (R-17) (it is similar to aluminum bubble insulation but more efficient) with carpet on top... any ideas for carpet would be appreciated.
