I brought home this 2017
Casita to keep my 1992 13'
Scamp company.
I bought the 13'
Scamp a couple of years ago on impulse. I wanted a
fiberglass trailer and didn't know what I wanted or needed. I had to buy something to get a feel for what was most important.
Turns out the 13' does everything I need it to do when camping in campgrounds which is why I'm keeping it, plus it's sentimental.
It can probably be said this 17'
Casita was an impulse buy as well. I just started thinking that for some trips it might be nice to be able to boondock and have a shower/toilet. I started looking at Scamps and Casitas with bathrooms. I ran across this one here in the classifieds. I think I overbought, but many of the add-ons are items one might purchase anyway right?
Taken from the sales ad: (I figured it had everything I'd need for boon docking plus some.)
ROOF TOP SOLAR SYSTEM:
-2-100 Watt Renogy Eclipse
Solar Panels (roof mounted).
-Bogart Trimetric
Battery Monitor and Bogart 30AMP
Solar Controller.
-Samlex 2000 Watt Pure Sine wave Inverter with remote.
-Two Lifeline GPL-6CT 6 Volt, 300 Amp Hour Deep Cycle AGM batteries.
-PD4655V 55 Amp 4 stage smart charger/Converter Upgrade, with the Optional Remote Pendant.
FACTORY TRAILER OPTIONS:
-This
Casita Independence allows a couple to enjoy the convenience of two twin beds that easily convert to a KING bed. Allows for easy access to the kitchen & bathroom without disturbing the other person.
-The spacious beds allow for more under bed storage with ease of access compared to other Casita’s.
-Three large fully-openable screened picture
windows provide extra cross ventilation, ample natural
lighting and scenic wrap-around viewing.
-Deluxe model features spacious shower and toilet.
-Mach 1 air conditioner with heat strip was chosen for reliability and low noise.
-Gas
furnace.
-Fiamma
Awning.
-Upgraded 25 gallon fresh water tank.
-Fantastic Fan and Max Air cover in living area.
-Vinyl flooring.
-3-way
Refrigerator 4.0 cu ft.
-3-Burner Range with Power Vented Hood.
-All interior and exterior
lights are factory installed LED.
-Extra factory installed 12-volt outlets next to beds.
-Storage cabinet is wired for
microwave; new stainless
microwave included.
-High lift
axle with 15 inch
tires, spare, cover and wheel locks.
-Spare was not mounted to the Casita, uses a custom Orbital aftermarket bracket.
-Outside Shower/Wash Station
-Electric Tongue Jack
-Cable Ready
-Two Corner Shelves.
-Custom ordered with no “Casita" Decals.
AFTERMARKET CUSTOM UPGRADES:
-Two custom retro designed tables.
-Custom designed retro corner shelves.
-Custom Tempurpedic Memory Foam Twin Mattresses that convert to King bed.
-Custom retro designed upholstery and curtains.
-Digital thermostat upgrade controls A/C and heat just like your house.
-24” Samsung HD TV.
-Exterior
porch light controlled from inside.
-Upgraded metal high rise sink faucet.
-Custom fold-down work/kitchen space.
-Custom closet shelves installed.
-Orbital Machine Works (OMW) Spare Tire Mount.
-Onboard Honda 2000
generator.
-Anderson anti-sway control and
weight distribution hitch.
-Heavy duty scissor jacks on all four corners for leveling and stability.
-Custom PVC compartment for easy sewer hose storage.
-2” rear receiver hitch for rear storage or bike racks.
-Teak shower floor.
-All cabinets upgraded to custom
light weight solid Poplar wood and custom painted (paint booth sprayed) retro teal with Behr Premium professional
paint.
-All new Retro door hardware
-Orbital Machine Works shock absorber Kit. Produces a much smoother ride. It reduces broken rivets, cushions on the floor and open cabinet doors on very rough roads.
generator platform and LoPro
generator lock down system for included Honda Generator.
-Little House Customs installed Fast Gray Modification, increases your capacity and dump speed by allowing you to dump previously trapped gray water.
-Little House Customs installed Vent upgrade, increases capacity by 8 gallons and improves dump speed.
-Little House Customs installed toilet supply shutoff valve.
-Little House Customs installed Max Air Vent Cover, allows you to keep your vent open in the rain. It also allows ventilation while in storage.
-Little House Customs installed BAL 7500lbs SCISSOR jacks. Strong enough to lift the Casita to change a flat.
-Little House Customs installed Hitch mounted spare tire mount.
Furnace Insect Screen and Water Heater Insect Screen
-Little House Customs installed screen door push bar, gives something to wrap your entire hand around when unlatching the door in a strong wind.
-Little House Customs installed Lighted Water Pump and Lighted Water Heater switches. Leaves no doubt as to what is turned on and running.
-Little House Customs installed 2-way
porch light, turns
porch light on or off from either the inside or the outside. No need to open the door to turn the
light on.
-Little House Customs installed Custom RV Widget Storage modules.
-Brand new spare bearings and anode.
-Bargman amber porch
light lens.
-Coiled break away cable.
-Rhinoflex sewer hose.
-Spare rivet kit.
-Shore power rubber bug guard.
-Sneaky Pete Gray Water sewer adapter.
Ad can be seen here:
https://www.fiberglass-rv-4sale.com/...-gypsy”-sale-0
Inside photo from the ad:
