Remove Original Interior Burro Lights - Fiberglass RV
Old 11-09-2017, 08:48 AM   #1
Trailer: Burro
Anyone know how to remove the original lights in the Burro without messing up the fiberglass too much?
The lights I'm referring to are the square lights on either side of the cabinets above the sink/stove. I see where they are screwed through the fiberglass with two screws each (mine have been heavily pained over on the back side). I can't quite figure out how to get to the head of the screws to take them out, there has to be a way to open these lights - I mean people had to change the light bulbs at some point right?
Any help is greatly appreciated - I tugged and pulled as much as I was comfortable with, but I worry about damaging the fiberglass.
wxmixte is offline   Reply With Quote
Old 11-09-2017, 08:59 AM   #2
Missouri
covers
do yours have covers over the bulbs? my scamp had I took them off then had to remove the rivits they use to attatch the fixtures to the cabinents. Scamp like rivits!
bob
Old 11-09-2017, 09:55 AM   #3
Trailer: Burro
bob
Yes there are square clear covers over the bulbs, but I don't see any way to remove them - seems like they are glued down or something. Here is a photo I found - here are some photos:
Old 11-09-2017, 11:44 AM   #4
Missouri
covers
the covers should slide off don't try to pull them off. you might try squeezing them and they will pop off. once off you will see how they are attached I took mine off and put on leds! much better light to me!
bob
Old 11-09-2017, 11:49 AM   #5
Trailer: Burro
bob
Bob, Thank you! Any clue on which way they should slide off? We have the same plans! LED all the way!
Old 11-09-2017, 11:50 AM   #6
YourHighness's Avatar
Trailer: Burro
Alabama
The lenses have two tabs on the top and two tabs on the bottom. Use a thin bladed screwdriver to carefully been down the top or bottom to pop the tabs off and then the bottom will come off. Then you can reach the screwheads that attach them to the wall.
Rudy
YourHighness is offline   Reply With Quote
Old 11-09-2017, 11:51 AM   #7
Missouri
covers off
if you are going leds don't worry just get them off anyway you can! this is what I did on the first one then I saw how they worked. Threw the old ones in the trash.
bob
Old 03-11-2018, 05:23 PM   #8
Trailer: 94 Scamp 13 ft
Did you replace the light fixture? I'm looking for one of the switches that slide on the side that turn the light off and on.
Sheryl M is offline   Reply With Quote
Old 03-11-2018, 07:23 PM   #9
Trailer: Burro
Sheryl,
We have not taken them off yet, but will be removing them next week or the week after. Do you mean you are looking for these lights? I do not think we will have any use for them since we are planning on replacing them all together.
If you do need them send me a PM!
- Ashley
burro, lights, light
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
Original 1976 Boler interior Lights Gord Plowright Classified Archives 0 06-20-2006 08:11 PM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
