1975 Ventura Floor - Fiberglass RV
Old 09-18-2018, 09:46 AM   #1
Trailer: Venture 400D
Manitoba
1975 Ventura Floor
Hello all, I need advise on the floor for a 1975 Ventura floor. I pulled out the pcs that was on. It was 3/8 think. I notice there were holes on the fiberglass to attach to the frame under the camper.
Should I just patch up the fiberglass?
What thickness of floor should I use?1/2 or 3/4?
Should I use a jack to raise the fg to meet the plywood because of low areas?
I noticed the fg doesn't sit on the frame on the btm? Is it suppose too?
Thanks for the help.
Gerry
GerryP is offline   Reply With Quote
Old 09-18-2018, 12:24 PM   #2
Trailer: Ventura
AB
What I did…
Hi Gerry,
I patched the holes with Marine-Tex and used 3/4" untreated plywood. I replaced the bolts and added larger washers to prevent them from pulling through. Then I used coated self-tapping screws (Teks) in a few places driven through the plywood into the frame below. My fibreglass did not sit on the frame in a few places either. I just left it as-is. The plywood under the front bench was okay, so I just added some extra 1/4" ply washers to clean up the existing holes.
Paul Lewis is offline   Reply With Quote
Old 09-19-2018, 10:42 AM   #3
MurrayC's Avatar
Trailer: Ventura
British Columbia (BC)
I did a full interior restore in my 77 Ventura last winter.
Make sure the floor fiberglass is in good shape. If not put down a new layer of glass first. Instead of trying to bond the new plywood floor to the wet fiberglass I did the glassing first and then glued down two layers of plywood on the new fiberglass. I put down 1 sheet of 5/8" and 1 sheet of 1/2". This made the door frame work well. Under the trailer I put wedge shaped treated lumber to re level the floor taking up the space between the steel frame and the fiberglass floor. You must put some sort of reinforcing here or take trailer off frame and install new steel framework. I used wood. As for any holes, put some glass mat down to seal them from water penetration.
I used premium adhesive to bond the plywood floor to the new fiberglass. And also glued the 2 layers of new plywood. This will make the floor solid as a rock.
Paul Lewis has some good ideas as well.
Good luck, its worth it. These are great little trailers.
MurrayC is offline   Reply With Quote
Old 09-19-2018, 11:15 AM   #4
MurrayC's Avatar
Trailer: Ventura
Ventura Reno
See underneath support and drip cap over door. These are a must do.
Old 09-19-2018, 11:21 AM   #5
MurrayC's Avatar
Trailer: Ventura
The floor looks familiar.
I also added some roof support.
Good Luck
Old 09-20-2018, 07:28 AM   #6
floor
24 inch toung extention tool box 4inch lift .all led light and front setee/ bed .new cabnets solar set up .work done by Retro Ranch Rv in Edmonton
Old 09-20-2018, 09:02 AM   #7
MurrayC's Avatar
Trailer: Ventura
This looks great. Good job.
Go and Enjoy.
Old 05-30-2020, 09:35 AM   #8
Trailer: Ventura 73’
I know this thread is from few years ago but thought I’d inquire - any tips to pulling up the floor without removing the door?
murffie is offline   Reply With Quote
Old 05-30-2020, 10:03 AM   #9
Ventura
I take the door and frame/casing out as one unit way easer the wood on mine was all roten. i put down pressure treated fence boards and foam insulation then plywood.
Old 05-30-2020, 10:10 AM   #10
I figured door needed to come off. Dang.. was hoping to avoid that.
Smart move with treated wood then plywood. I may do the same. What ply or thickness plywood?
Old 05-30-2020, 10:36 AM   #11
Ventura
i also extended the tongue 20 " and a 4" lift kit tows like a dream.
Old 05-31-2020, 11:08 AM   #12
Looks amazing! You’re giving me hope. Lol. Helps me eye ball some dimensions above with cabinets too.
How many inches are the bench’s spaced for the table?
Old 05-31-2020, 12:26 PM   #13
Ventura
Cant rember i just sold it in january.i allso have a Surfside in the works and a17' boler,anda beachcomber.all gut and redos not learning .lol
Old 06-02-2020, 12:56 PM   #14
Does anyone have images of structure, etc under the table plywood? Wanna know what I’m in for...
Old 06-02-2020, 02:27 PM   #15
Ventura
You can call Retro Ranch RV and ask them they worked on mine.780-893-9281.
Old 06-04-2020, 05:12 PM   #16
Trailer: Ventura
Edmonton
I have my trailer torn right down to studs and fiberglass floor if that's the pictures your looking for. Let me know and ill see if I can help.
TacomaJax is offline   Reply With Quote
Old 06-05-2020, 06:07 PM   #17
Ok... got the bolts out and table area plywood up today. A mix of victory quickly followed by discovery. Two lower spots behind the wheel wells had an inch or so of water (very old dark looking water). Endless discoveries eh! Felt like sharing. Click image for larger version
ventura
My 1975 Ventura adventure. streetvan1 Problem Solving | Owners Helping Owners 31 06-18-2020 05:28 PM
1975 Ventura Joe Frey Hi, I am.... 4 07-20-2012 05:43 PM
MB | 1975 Ventura 13' Rayzur Classified Archives 1 07-19-2012 04:44 AM
CANADA - 1975 - Ventura - $1800 David Tilston Referrals: Molded Fiberglass Trailers 2 06-25-2012 01:29 PM
1975 Ventura Barn Fresh Rocker Problem Solving | Owners Helping Owners 53 05-12-2012 05:06 PM
» Trailer Showcase
Tony
reeves99
2013
ohmydog2dee
