BC 2013 Escape 5.0 - $28,500 (Can) Kamloops B.C. - Fiberglass RV
Go Back   Fiberglass RV > Marketplace > Classified Archives
Old 08-09-2014, 11:36 AM   #1
Trailer: 05 Escape 17b
2013 Escape 5.0 For Sale: Kamloops B.C.
We are selling our trailer that was purchased new in March of 2013, it has been used very little as we were busy with a move last year. We are selling because we have purchased a lakeside cabin. We used a Nissan Frontier to tow with and had no problems. These trailers were designed to be pulled with mid size and/or half ton pickups. Escape trailers differ from other manufacturers in that the upper and lower halves of the trailer are laminated together and then removed from the molds, this results in a trailer that is one piece, structurally stronger and not susceptible to leaks at the “belly seam”. Purchasing an Escape trailer gains you entry into an enthusiastic owners community, and a product that the manufacturers Rease and Tammy continually stand behind.
The trailer is less than 7 feet wide, which is narrower than most trailers and has less aerodynamic drag. This will result in better fuel economy when towing. The overall length of the trailer is 19 feet. The trailer has not been smoked or cooked in, as well the black tank has had only “liquid” waste in it.
The trailer is located in Kamloops B.C. which is approx. 3hrs from Chiliwack where the trailers are built
For more information, check out the links to the Escape Trailer Website and the Escape owners forum.
Escape Trailer Industries – Chilliwack, British Columbia
Escape Trailer Owners Community
-Interior-
Maxx Fan Roof Vent - adjustable speed and direction, thermostat controlled as well
120V Thermostat Controlled Wall Heater - quiet heat when camping with hook ups
12,000 BTU Propane Furnace
Custom Sunbrella Fabric
Linoleum Flooring
Interior LED lights - use less battery than incandescent bulbs
2 LED Captains Reading Lamps Over Bed
Carpeted Stairs
Custom Wood Interior Finish
Oak Door Package
Pleated Draw-Down Window Shades
Valences Above Windows - finished with matching fabric
Ceiling Lighting - switched at door or ceiling
Double Insulation / Dual Pane Windows - heat retention and reduction of inside condensation
-Chassis-
Electric Brakes
Rear Scissor Jacks with Pads
Independent Power Landing Gear
Torsion Suspension
15" Radial Tires, Balanced (ST225-75R-15)
Full Size Spare Tire and Cover
2650 pound Dry Weight
4400 pound GVWR
-Electric-
120-Volt Interior Outlets (5)
120-Volt Exterior Outlet
12-Volt Interior Outlet
25' - 30-Amp Power Cord
55-Amp Converter with Battery Charger
EMS Surge Protector - protects trailer electronics from electrical damage
Removable Power Cord - keeps dirt and insects out of living area
Dual 6V Batteries - More than double the capacity of a single 12v
Pre Wired for Solar
-Kitchen Area-
3 Burner S/S Stove
S/S Sink with Ikea chrome faucet
S/S Range hood with Light
6.7 Cu Ft Dometic Fridge
Counter Extension off Sink
Sink Cover
Additional Window Above Sink
Custom Formica Counters (Slate Sequoia with Black Trim)
-Complete Bathroom-
Full Fiberglass Shower Insert
Sink with Hand-Held Shower Unit
Thetford Aqua Magic 5 Toilet
Privacy Door Lock
Power Ceiling Fan
-Exterior-
10' Fiesta Awning
3 Exterior Storage Hatches
20' Sewer Hose Storage
Dual 20 lb. OPD Propane Tanks w/auto Change-Over Regulator
3 Exterior Porch Lights (Driver, Passenger Side and Under sleeping area)
Mud Flaps
4 Exterior Bubble Levels
Large Factory Tinted Screened Windows
Entry Step
Spray Foam Insulation Underneath - keeps floor warm, helps prevent freezing of tanks, and soundproofs the trailer
Bike Rack Ready - 2” hitch
Battleship Grey Graphics
Aluminum Wheels
-Tanks-
12 Volt Demand Water Pump
20 Gal. Fresh Water Tank
6 Gal. DSI Two Way Hot Water Tank - 120v and propane powered
26 Gal. Grey Tank
19 Gal. Black Tank
Tank and Battery Monitor Panel
Filler Hose and Water Filter Included
-Safety/Fire Protection-
Emergency Exit Window
13" x 20" Escape Hatch/Vent over Sleeping Area
Fire Extinguisher
Propane & Carbon Monoxide Detector
Smoke Detector
-Seating/Sleeping-
4-Person Rear Dinette Converts to Double Bed
Queen Size Mattress with North/South Orientation
4" High Density Seat Cushions
[/URL][/IMG][/URL][/IMG][/URL][/IMG][/URL]//[/IMG][/URL][/IMG][/URL][/IMG][/URL][/IMG][/URL][/IMG]
"Bigger isn't Better, Better is Better"
Islandr is offline
Old 08-09-2014, 07:11 PM   #2
Islandr is offline
escape
MI | 2013, Sept. 6-8: Michigan Algonac Egg Scramble 2013... PaulOWindsor Rallies, Get-togethers, Molded Meets (Archive) 235 01-10-2014 10:00 PM
OR | April 25-28, 2013: Spring NOG 2013 – Northern Oregon Gathering Donna D. Rallies, Get-togethers, Molded Meets (Archive) 192 04-30-2013 10:12 AM
For Sale: Referral - Boler Parts, Kamloops, BC kijiji Roy in TO Classified Archives 2 07-24-2012 01:40 PM
beachcomber in Kamloops - could someone look at it? alan in alberta General Chat 3 07-14-2012 09:43 AM
