1974 Perris Pacer Renovation - Page 3 - Fiberglass RV
Old 10-02-2017, 09:40 AM   #41
Missouri
tooo fred
fred you are amazing that is all I am going to say!
best of luck
bob
Old 04-13-2018, 08:15 AM   #42
Trailer: Perris Pacer '87
VA
What did you use for the window gaskets?
ValleyReb is offline   Reply With Quote
Old 04-16-2018, 01:52 AM   #43
Fredomatic's Avatar
Trailer: 1974 Perris Valley Pacer
Mark, I haven't replaced the front and rear windows yet. Unless I find the rubber window gasketing locally, I will purchase it from the Scamp website. I have some ugly scratches on the plexiglass windows so I'm considering replacing them. I need to do some research as many plastics yellow in the sun over time.
Fredomatic is offline   Reply With Quote
Old 02-25-2020, 12:48 AM   #44
Fredomatic's Avatar
Well I ended up purchasing the windows and rubber seals from Scamp. Although the body is nearly identical, the Pacer isn’t a Scamp and the windows didn’t fit perfectly. I found a great auto glass installer that could trim the plexi and install them perfectly. Click image for larger version
ID:	133330Click image for larger version
ID:	133331Click image for larger version
Old 02-25-2020, 01:06 AM   #45
Fredomatic's Avatar
I’ve always loved cork flooring. I couldn’t afford to put it in my kitchen but I got it in my trailer. [emoji16]
ID:	133333Click image for larger version
Old 02-25-2020, 01:08 AM   #46
Fredomatic's Avatar
We reinstalled the side windows...Click image for larger version
ID:	133335Click image for larger version
Old 02-25-2020, 01:12 AM   #47
Fredomatic's Avatar
Then I broke a side lite, drat! These are original. I saved it with copious amounts of super glue and luck. Click image for larger version
Old 05-29-2020, 10:35 AM   #48
Trailer: Perris
Originally Posted by Fredomatic View Post
I just looked at a Perris Pacer that would need the floor replaced. What’s the trick to removing the furniture? It looks like everything is glassed in to place rather than riveted like the Scamp. Any advice is appreciated. Thanks!
BillBones is offline   Reply With Quote
Old 05-29-2020, 11:33 AM   #49
Fredomatic's Avatar
Sub floor pic
Old 05-29-2020, 11:40 AM   #50
Fredomatic's Avatar
Bill, in my Pacer all the cabinets were riveted in except the closet which was all glassed. I drilled out the rivets and simply lifted the cabinets out. There were a few lateral fasteners between the rear bunk and closet and bunks and the kitchenette. They unscrewed easily.
In my Pacer the bottom of the coach is all fiberglass then there is 1/2” ply on top or inside. Originally the linoleum floor was glued to the plywood. I didn’t remove the ply wood. I may be wrong but It looks as though it is glassed to the bottom so it will be a hassle to remove the wood without damaging the fiber glass bottom. Having a fiber glass bottom is great as it’s all sealed. From what I’ve read, the older bolers had plywood bottoms that were prone to rotting out.
Attachment 135036
Old 05-29-2020, 12:31 PM   #51
Fredomatic's Avatar
After the lower bunk cabinets were fitted, I started refurbishing the rear cabinet which holds the table. The cabinet frame is the only wood remaining from the original build. I recovered it and test fitted it with new swing arm table brackets. I ended up going back to the original post mount components as the swing arm hardware is unfinished and has somewhat sharp edges. I finished the shelf and mounted a fresh table top to keep with the natural material stying. Woo woo! Moving forward.
ID:	135049Click image for larger version
ID:	135040Click image for larger version
ID:	135041Click image for larger version
ID:	135042Click image for larger version
ID:	135043Click image for larger version
ID:	135044Click image for larger version
ID:	135045Click image for larger version
ID:	135046Click image for larger version
ID:	135047Click image for larger version
Old 05-29-2020, 01:10 PM   #52
Trailer: Perris
…Having a fiber glass bottom is great as it’s all sealed. From what I’ve read, the older bolers had plywood bottoms that were prone to rotting out.
I was surprised by the sealed bottom as well. The existing floor is very delaminated from a leaking roof vent that’s since been replaced. If I purchase it I’ll probably have to use a grinder to get the last bit of old flooring out. The camper I looked at was a 1988, so building methods for the cabinets probably evolved over the years.
Thank you for your help. Your Pacer looks great!
Old 07-13-2020, 06:17 PM   #53
Love the cork floor.
Jenius is offline   Reply With Quote
perris pacer
1974 Boler renovation complete!! EwaW Modifications, Alterations and Updates 12 06-23-2015 02:11 PM
1982 Perris Pacer Renovation Robert Johans Modifications, Alterations and Updates 55 03-21-2015 12:14 AM
NM | 1974 Perris Pacer $6500/OBO SJTrujillo Classified Archives 2 02-17-2014 11:32 PM
1974 Boler renovation started today Tom in Meigs Ohio Care and Feeding of Molded Fiberglass Trailers 0 10-25-2013 11:11 PM
