Amerigo Progress......Finally! - Page 3 - Fiberglass RV
Old 03-12-2017, 06:54 PM   #41
SteveV's Avatar
Trailer: Amerigo FG-16
It was time to start on the seating & bed bases. I upgraded the rear bed from the 5/8" plywood that it originally had to 3/4". I also added a piece of 1 1/2" angle iron salvaged from an old bed frame to the underside since there wasn't any support there before. There was about an 1 1/2" of sag in the old bed by the back wall! The hatch doors were about the only wood in the rear that could reused.
SteveV is offline   Reply With Quote
Old 03-12-2017, 07:11 PM   #42
SteveV's Avatar
The center fridge cabinet was next. I'm coating everything wood with either paint, stain and clear polyeurathane on all sides with the hope it will prevent future rot or mold.
That translates into it takes a lot longer to make progress!
Old 03-12-2017, 07:46 PM   #43
SteveV's Avatar
Overhead cabinets were next. In the original build the factory did the wall paneling first then hung the cabinets over the top part of the wall. That means that any wall panel replacement requires the cabinets be removed first which pretty much means destroying them. My fix was to cut a 1/4" rabbet joint into the bottom rear of the cabinet. This will allow the new wall panel to simply slide up behind the cabinet w/o removing them.
I wanted to get away from the dark black walnut wood tones but didn't want to get into refacing or replacing the doors. Then the idea hit me to simply turn the doors around. That put the dark wood color on the inside & I then sanded/stained the original inside of the door which was just an unfinished luan type of wood. Perfect!
Old 03-12-2017, 08:22 PM   #44
tractors1's Avatar
Trailer: Escape 21 - Felicity
Brilliant solution. Ain't that flash of thoughtful fix great?
Charlie Y
Old 03-13-2017, 07:10 AM   #45
Jon in AZ's Avatar
Agree! I also thought the fiberglass hatch door replacements were nice. I like that you left the fridge access panel in place, minus the vents. It leaves the option open for the future.
Old 03-13-2017, 11:20 AM   #46
SteveV's Avatar
Yes & it was a well needed relief as it seems like everything else on this project has taken the hard road.
I have the closet wall & door frame set now. It's amazing how much strength 1x2's & 1/4" sheeting has when you start stapling, gluing & screwing all of the parts together. The ceiling had sagged about 1/2" so I put temporary bracing in until the closet wall was put together.
Built the front bench & 'glassed it in place once the wall was up. Just like on the rear bench I was able to reuse only the hatch door.
Old 03-13-2017, 11:37 AM   #47
SteveV's Avatar
I plan on adding a small window ac unit using the upper part of the fridge access area & making a slide type of mounting for it. When in use it'll stick out past the door, when not needed it will retract into the former fridge location. A smaller dorm type electric fridge should fit below the ac. I'll need to make a second fiberglass door with the cutout for the ac & change it out when the ac is needed.......at least that's the idea bouncing around in my head right now!
Old 03-13-2017, 05:10 PM   #48
Kai in Seattle's Avatar
SteveV,
So glad to see and hear your progress! So clever to turn the doors around, preserving original and your sense of aesthetics at the same time!
Lots of ways like ours, lots of ways different, love to see your choices!
We, too, had to prop up the ceiling as it had also sagged some. Luckily the fiberglass is forgiving to the extent we needed.
You're moving right along! Thanks so much for the updates!
BEST
Kai
Semper ubi sub ubi.
Old 03-13-2017, 07:02 PM   #49
SteveV's Avatar
Thanks Kai! I've been looking closely at your pics & the other Amerigos on this site for ideas. Hopefully it'll look like a camper again soon.
Old 06-12-2017, 10:36 AM   #50
Docbear2017's Avatar
Great job Steve. I am also refurbishing a 1971 Amerigo. This past weekend I built the rear seating area and enclosed the cargo area. I will be storing all electronics and battery there. The window ac idea is a good idea. I cut out a area for the ac to pass through the wall. I would like to fabricate a fiberglass panel to permanetly fix above the ac unit. kinda like an eyebrow.
Docbear2017 is offline   Reply With Quote
Old 06-20-2017, 04:53 PM   #51
SteveV's Avatar
I've made some good progress in the last few weeks.
The galley has come together without too much trouble. I did get rid of the oven as I didn't think we would ever use that appliance. Honestly I don't think the 2 previous owners ever used it either as the inside of it looked brand new. I separated the stove top from the oven and reused it, I had to cut the stainless trim to make it look like it came that way.
A small microwave will go in the space below the stove top now. I stained & cleared the plywood countertop for now but will keep my eye open for some formica to cover it with down the road. I may still add a gas furnace below the micro so that will be left unfinished for a while.
Old 06-20-2017, 05:02 PM   #52
SteveV--oh, yes, VERY nice! I like the idea of a microwave beneath the cooktop--that's where ours is (though without the cooktop). a gas furnace since you have propane might be a great idea; didn't you once say you were planning on using this partly during the winter?
I'm glad the oven and its supposedly dangerous furnace are gone! What dangers lurk in the misty past will never truly be known...but there is some evidence that there was once a carbon monoxide problem with those furnaces.
Meanwhile--looking really good!
Thanks for the update!
Kai
Semper ubi sub ubi.
Old 06-20-2017, 05:06 PM   #53
SteveV's Avatar
I'm getting to the fun part now....installing some finished wall panels! It's a great feeling to finally get to this stage of the project.
I still need to finish the rear bench for the front dining area. I don't really care the aluminum trim they used to finish off the seat back & end piece & debating alternatives......
Old 06-20-2017, 05:15 PM   #54
SteveV's Avatar
Here's a few pics of the semi-finished back end. I plan on trimming the windows with some 3/4" x 1/2" oak that I still need to rip on the table saw. The third brake light is mounted on the inside of the rear window.
Old 06-20-2017, 05:20 PM   #55
WOW, you're really getting there! One of these days you'll realize you're done--
Super! Looks great!
Kai & Paul
Semper ubi sub ubi.
Old 06-20-2017, 05:27 PM   #56
SteveV's Avatar
I have had some extra help the past few days.......this little guy has been hanging around. I think he's wondering when his move in date is!
I plan on using a small dorm fridge but I did run a new gas line to the fridge area to keep the propane option there.
Kai, We planned on Summertime/fair weather use but our last NC outing in April was in the low 40's so a furnace sounds good to me!
Old 06-20-2017, 06:00 PM   #57
John in Michigan's Avatar
Trailer: 1979 Boler 1700
wall panel product?
Steve, what product did you use for the wall panels?
Old 06-20-2017, 06:29 PM   #58
SteveV's Avatar
John, I used a 1/4" luan/flooring underlayment from Home Depot. I cut /fit the pieces, primed/painted the backside, primed the front side w/wallpaper primer (sizing) & applied a textured vinyl wallpaper before I installed them. Yes, it was a giant pain but figured I only have to do it once! I was able to reuse the original plastic trim pieces along the top & inside corners.
Old 06-21-2017, 08:56 AM   #59
Love the little guy--and the trailer!
You kept that flip-up countertop extension or added a new one, I see...handy!
Looks like you enlarged the door for the "Putin" (front closet we use to hold the porta-potty and so much more); we enlarged that opening, too, but use a beach towel/curtain instead of a door.
I remember you wrote about a dorm fridge, which I think is a super idea (we're still using an ice chest and probably will continue to do so)...
I love how yours is coming along and how it looks!
At 40F outside, yes, agree about the furnace!
So far we need electricity. We carry water though we don't scorn campground water, especially for my solar bucket bathing and the girls (we gave them a wading pool in Nimble's nighttime nest at Maryhill last month--it was over 80F and the girls were lethargic with heat ...--we use a plastic barrel liner (the shallow kind) for her bed underneath the back bed--works great for a wading pool ).
Enclosing some shots like yours for comparison--your photos seem much clearer but the trailer resemblance is uncanny !?
Final pic: Paul made me a fairly big, heavy key fob...if you'd like one, let me know. We keep it on a hook by the door nearest where Peanut lives most of the time for quick access-hard to lose, hard to forget. We would be delighted to send you one.
BEST
Kai
Semper ubi sub ubi.
Old 06-21-2017, 05:51 PM   #60
SteveV's Avatar
Thanks Kai!
I did reuse the original doors. The closet/toilet area had a sort of bi-fold door on the inside that opened/attached next to the stove top giving a little larger private area when using the "seat". Since I'm not carrying a porta pot I won't reuse the extra inside door. Also with the closet door hinged on the left side it is awkward to open from inside the camper....you have to litterally be standing outside of the camper, open the door then step in. Switching to a right side hinge is on the to do list.
That is a cool looking key fob! Is it from one of your old emblems?
I am working on making a mold from one of my good unbroken emblems so I can reproduce a few of them.
amerigo
Seattle Area -- Tour of an Amerigo Trailer, in progress Kai in Seattle Problem Solving | Owners Helping Owners 0 11-11-2015 11:05 AM
Photos of Amerigo FG-16 remodel progress Campin_Idaho Modifications, Alterations and Updates 0 01-05-2015 10:21 PM
New Amerigo Owner - FINALLY.... Need Advice. cvc0922 Problem Solving | Owners Helping Owners 26 02-18-2014 01:01 PM
UT | New Amerigo Owner - FINALLY.... Need Advice. cvc0922 Classified Archives 0 02-11-2014 02:07 AM
Finally, Finally... Richard Hayes Hi, I am.... 11 06-16-2012 09:35 PM
