Ventura window leak found..ideas how to fix? - Fiberglass RV
Old 07-22-2016, 08:44 PM   #1
Trailer: Ventura
Manitoba
Yes me agine sorry lol but you guys are so awsome on ideas )
So the corner of my door window leaks after much testing I found where ( outside left corner ) I'm at option A.seal window closed or B. Attach a cup somehow to inside to catch drips lol anyone have better ideas? I have a lace screen door drape so no window not opening won't make me cry
Cheyanna83 is offline   Reply With Quote
Old 07-22-2016, 09:20 PM   #2
Trailer: Trails West
Forget the cup....that is a mug's way of fixing issues and you are going to end up with rot and mold if you pursue that course. Hopefully you were just trying to be funny, I was certainly amused by it
If you must do a quick fix use some Captain Tolleys, you are likely to need 5 or 6 applications of the Captain Tulleys for to find its way in to seal up the void. Follow the application directions.
But truthfully you should do the job right, take the windows out, rehabilitate them and then reinstall using new seals to replace any old ones that have started to deteriorate.
Old 07-22-2016, 09:24 PM   #3
Trailer: Ventura
Manitoba
Yes just frustrate with this door lol been a boatload of issues..I see no way to remove it if so I'd played with idea finding a cheap solid window to plug in,but I see no screws or anything if I had a grand I'd buy a new door lol ..
Old 07-23-2016, 10:06 AM   #4
There are only a couple of ways it could have been installed, so it won't take very long for you to solve the puzzle of how it was done. Don't give up so easily. Look for clues.... such as screws or on the inside of the door maybe there were separate pieces of trim applied against the main window frame, or even both things. The screws might be along the inside of the framing in the track where the window slides.
Don't you like to solve puzzles now and again? Try to get out of frustration mode and get into "how did they do that??" mode.
ventura
Ventura door leaking top left corner- baffled how to fix Cheyanna83 Problem Solving | Owners Helping Owners 5 05-23-2015 05:00 PM
'76 Trillium Belly Band Leak Fix georgewa Modifications, Alterations and Updates 6 04-12-2014 09:29 AM
Leak Fix - I Hope fusedlight Modifications, Alterations and Updates 12 05-17-2013 03:27 PM
What to use to fix wheel well leak in Burro??? Laurie T Care and Feeding of Molded Fiberglass Trailers 1 07-22-2010 04:17 PM
Leak FIX, PLEASE rickster Problem Solving | Owners Helping Owners 15 03-30-2006 09:26 AM
