SCAMP axle question - Fiberglass RV
Old 10-03-2016, 05:18 PM   #1
Trailer: Scamp 16
SCAMP axle question
Hello Everyone,
I'm thinking about purchasing a 16' scamp with wheel hub broken off. I did some researching and the drive axle seems to be welded on to the chassis. Does anyone know if I can purchase a hub replacement from the factory?
Fibernewbie is offline   Reply With Quote
Old 10-03-2016, 05:38 PM   #2
None
To know for sure, you would need to call them. If they don't have one, they can probably get you in touch with the axle manufacturer.
How old is the axle? If it is getting on to 15 or 20 years, It may be a better idea to just get a new axle. Torsion axles eventually wear out and loose their ability to absorb road shock.
I replaced mine on my 1999 13 ft Scamp this past spring. Ordered the complete axle from Scamp - quicker than ordering from the manufacturer. Had a local shop cut off the old axle, then, with phone instructions from Scamp, fabricated a mount that allows the axle to be bolted on. Next time the axle needs changing, it will be much easier.
LyleB is offline   Reply With Quote
Old 10-04-2016, 02:08 PM   #3
Did the axle break ?? The hub attaches to the axle spindle with just one large nut. Replacement hubs are readily available from many online and local sources. If the spindle is bent or broken or damaged, the axle needs replacement. Can you post a photo?
Old 10-04-2016, 03:07 PM   #4
Originally Posted by Fibernewbie View Post
Hello Everyone,
Trailers have "trailing axles", not "drive axles"
axle, scamp
Best (easiest?) way to lift a Scamp 5er - New axle vs Axle-Less Trailer Suspension dreschool Towing, Hitching, Axles and Running Gear 7 06-26-2015 04:28 PM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
