OK, I am doing some work sprucing up the interior of my little 1980
scamp and there are two things I am looking for some feedback on.
1) Between the door and the front bunk
fiberglass, there is a gap, maybe 1/2" in some areas. The PO used silicon Caulk in there (and it actually looked pretty good). I removed the Caulk to make it "better".
Question: is there anything I can really do (structurally or otherwise) to make it look/function better. Other than just re-caulking?
2) The wires running to the 120V lamp above the sink are unsightly, the PO put white tape over them (as you can see in the pictures), how is this
light typically wired in?
3) I want to put an exterior
light on the outside near the door , since all
electrical is on the "opposite side" of the trailer, what is the best way to get some 12V wiring over there. i could run 1/2 " pvc under the trailer, or do I just run wires under the dinette (following the fresh water line) and do it that way. any other suggestions are appreciated as well.
I also want to run LP to that side to place a valve for a small flat heater to go under the closet door
Thanks. Jimbo
