Finished Paint on 75 boler - Fiberglass RV
Old 04-08-2010, 10:03 AM   #1
Trailer: 1975 Boler
I finished my tremclad paint job on my 75 boler and moved it out of the garage. Now its onto finishing the inside.
Roy Kleiner is offline   Reply With Quote
Old 04-08-2010, 11:37 AM   #2
Raya's Avatar
Looking good
I can't remember if you've mentioned this or not, but did you follow the inspiration of the "$50 paint job" Dodge Charger guy?
Raya
Old 04-08-2010, 02:12 PM   #3
Trailer: 1975 Boler
Yes with some other input...lol. A guy I work with told me about painting with tremclad last year. He was an auto body guy back in the day. I'm not sure if I took it real serious until I saw the charger photos and some of the other $50 paint jobs.
Old 04-08-2010, 02:42 PM   #4
Raya's Avatar
So how did it go? I read *pages* of that Charger thread - kind of got sucked in
Ever since then I've been curious to hear from someone else who's tried it.
Old 04-08-2010, 07:50 PM   #5
Trailer: 1975 Boler
It is a great low budget option for a nice paint job. In some of the forums they went from 20 to 50 percent mineral spirits. I went with 10 percent mineral spirits added to a gloss white. After 2 coats I gave it a quick wet sand with some 400 grit paper. I put on 2 more coats and then said maybe someday Ill sand it out with 1000. On the bottom I used a rocker guard spray to give it some texture and the used a mix of flat and semi gloss black also with 10 percent mineral spirits. My garage was on the cool side so it took a little longer to dry. Now I'm going to finish the upholstry. Watched a few you tube videos on upholstry and almost half done that part
Old 04-09-2010, 05:42 AM   #6
Trailer: Boler 1972
[quote]I finished my tremclad paint job on my 75 boler and moved it out of the garage. Now its onto finishing the inside.
Attachment 27325
Wow !
I have a 72 boler and I wish I paint it ! But I'm not sure I can do it my self. Il love hub cap to. Where do you buy them?
and... sorry for my basic english ...lol
Nicole L is offline   Reply With Quote
Old 04-09-2010, 08:03 AM   #7
Trailer: 1975 Boler
I got them from wall mart. The were scratched so they had them marked down. I think they were less than 10 dollars
Old 04-12-2010, 01:47 PM   #8
Randy D.'s Avatar
Trailer: 1975 Boler 1300
That looks fantastic. I will be following in your footsteps for sure.
Randy D. is offline   Reply With Quote
Old 05-12-2010, 11:05 AM   #9
Trailer: 1973 13 ft Boler (Corneleus)
Any way you could do some step by step instructions of what you did with regards to this paint job. we will be painting the outside once we get the frame back on.
Can you let us know what prep work youhad to do to get it so nice looking??
Cheers
Ursula
ursulap is offline   Reply With Quote
Old 05-12-2010, 05:19 PM   #10
MyronL's Avatar
Trailer: Escape
New Mexico
Angry
My understanding is Tremclad and Rustoleum are identical paint products. Is that right? Here in New Jersey Home Depot sells lots of Rustoleum but I have't seen any Tremclad. I need reassurance. Should I not be at all nervous about using Rustoleum for my Scamp's roof restoration?
MyronL is offline   Reply With Quote
Old 05-13-2010, 06:53 PM   #11
Pamela S.'s Avatar
Trailer: 1984 Fiber Stream
Roy,
Could you explain a little bit more about how you did the upholstery? It looks like vinyl or something. Looks great.
Pamela
Pamela S. is offline   Reply With Quote
Old 05-15-2010, 04:54 PM   #12
Trailer: 1974 Hunter I
[quote]It is a great low budget option for a nice paint job. In some of the forums they went from 20 to 50 percent mineral spirits. I went with 10 percent mineral spirits added to a gloss white. After 2 coats I gave it a quick wet sand with some 400 grit paper. I put on 2 more coats and then said maybe someday Ill sand it out with 1000. On the bottom I used a rocker guard spray to give it some texture and the used a mix of flat and semi gloss black also with 10 percent mineral spirits. My garage was on the cool side so it took a little longer to dry. Now I'm going to finish the upholstry. Watched a few you tube videos on upholstry and almost half done that part
Attachment 27334
Hey Roy that looks good!! I am getting ready to try my hunter with this method. I read the thread the Charger guy did,looks Great!I am in the process of sanding down some of the old paint that was brushed on and it has a lot of brush marks. Mainly I am taking it down smooth and not always taking all of the old paint off. How much paint did it take to do yours? Did you use the small high density foam rollers? Thanks Harold
harold f is offline   Reply With Quote
Old 05-15-2010, 06:52 PM   #13
Roy, the only problem (that may NOT occur) is putting paint over old paint. Some types don't mix for instance. You may want to check out this topic, it's sounded similar to your problems.
Fixing "Mr Ugly"
Old 08-24-2014, 09:37 AM   #14
Trailer: 1974 13' Boler
Hey Roy did you use a primer first before you did the Tremclad?
Ronise99 is offline   Reply With Quote
Old 08-24-2014, 10:59 AM   #15
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Welcome to the forum!
I don't think Roy is going to answer you. This thread is from 2010 and Roy hasn't been active since then.
You may want to search the forum for newer threads that may have your answer.
Spanke
Trilliums Rock!
Spanke is offline   Reply With Quote
Old 08-24-2014, 11:04 AM   #16
Ok thxs Spanke, new to the site just purchased my 1st boler so getting used to finding out how to search for things on here
boler, paint, painting
Painting the boler. How much paint? colin k Modifications, Alterations and Updates 15 05-18-2018 10:16 AM
Finished Valance Casita Leehman Modifications, Alterations and Updates 2 05-04-2010 07:02 PM
Cost to paint a Boler? Does anyone know? ericmarlo General Chat 4 05-22-2008 08:25 PM
removing paint from Boler outside Judy Powell Problem Solving | Owners Helping Owners 1 07-10-2007 11:01 AM
Finished! Recently renovated 1972 Boler on display :) Darren C Care and Feeding of Molded Fiberglass Trailers 9 09-07-2006 10:28 PM
» Trailer Showcase
El Macho
eblues
Happy
janel
