07-29-2014, 12:45 PM
Trailer: Boler 13'
Fiberglass Cutting and Cleanest Tool to Use
I would like to cut down another inch of my boler closet fiberglass behind the door without removing the cabinet. Which would be the best and cleanest tools to use and type of blade. Any suggestions would be very helpful. Thanks
07-29-2014, 12:57 PM
A multi tool, Harbor Freight sells a cheap one. I use the half round blade or you can use a a metal cutting type blade. Hold a Shop Vac hose next to the blade while cutting to capture most of the dust.
Eddie
http://www.harborfreight.com/catalog...q=multi%20tool
07-29-2014, 02:52 PM
The absolute cleanest cut and maximum control comes from using a Dremel 565 Mulit-Purpose Cutting Kit 565D. Amazon Sells them.
I was totally amazed at how easy it was to control and how smooth a cut it made.
07-29-2014, 03:01 PM
Trailer: U-Haul VT16
Jigsaw
07-29-2014, 03:23 PM
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Originally Posted by mszabo
Jigsaw
I've tried a jigsaw, it seems to want to chip out on the edges, even with a metal cutting blade. I've used the oscillating type tool that Eddie suggested with very good success, providing a really clean cut, easy to control. Haven't tried the attachment for a Dremel tool that Byron suggested but it looks like it might work cleanly also, similar to a roto-zip tool for cutting electrical boxes in drywall.
My 2 cents!
Spanke
Trilliums Rock!
07-29-2014, 03:40 PM
Trailer: 1971 Boler
I used a angle grinder for any fiberglass mods I have made. Use masking tape as a guide and it goes real easy.
07-29-2014, 03:51 PM
Eddie
Search results for: 'multi tool'
Yesterday I cut a hole for a storage compartment access door under the dining seat on a Casita I'm refurbishing for sale.
I've cut many holes in fiberglass with the above tool.
It's a very clean cut.
I don't make a habit of buying H F electrical tools but for the limited use it gets I don't see the necessity for buying a more expensive tool.
07-29-2014, 04:59 PM
My 2 cents!
Spanke
I purchased and used that tool to cut a hole in bench to mount a propane detector. Looking at what Scamp and what I did will make a firm believer of you. The edges are perfectly smooth. There is no chipping at all. The only draw back is there's a lot of fine dust created. I was worried about control and cutting a line drawn with a sharpie. The control was great, no tendency to wander. I really surprised that none of you discovered this tool and how easy it is to use.
07-29-2014, 06:06 PM
North Florida
I just happen to own the finest oscillating tool extent, the Fein. And I used it, once, to cut a hole in my Scamp. After that experience I have used a jigsaw each time hence. The Fein worked superbly but was painfully slow and created a ton of very fine dust. The jigsaw, with suitable blade, works great and is quick and controllable. I also have the HF oscillating tool and can say that it is a best buy for what they get for it. I have it as a “loaner” or to have out on the job because I am not taking my eyes off my Fein.
07-29-2014, 06:45 PM
Trailer: 1983 scamp 13
Any of these tools will work but you will want a carbide grit blade to cut with. It will cut the best with little effort and last.
07-29-2014, 07:06 PM
Trailer: 2010 Scamp 16
If you are going to use a jig saw get a fine tooth "up cut" blade. Normally jigsaw blade the teeth are angled to cut on the down stroke, up cut they are angled to cut on the up stroke. On the up stroke the blade is pulling into the shoe which cuts vibration and chatter way down.
Cutting through masking tape will help control splintering and chipping, some masking or duct tape on the jig saw shoe to keep it from scratching surface is also good. I would think the same for the dremal tool foot.
07-29-2014, 08:09 PM
Air powered die grinder with a thin cutoff disc
07-29-2014, 11:53 PM
Trailer: Bigfoot 3000 & Barth "slide-in" truck camper
Connecticut
That won't cut a strait line without some sort of guide.
07-29-2014, 11:55 PM
Connecticut
I second that.
07-30-2014, 06:22 AM
Trailer: Boler13/trillium4500/buro13
The easiest way to make a strait and sharpest cut is to use a grinder with a diamond tile cutting blade and then use a multi function tool on the corners .i have found this to be the best combination
07-30-2014, 07:16 AM
Connecticut
Grinders are fast and easy but extremely messy. They out dust everywhere. An environmental suit with hood, goggles, gloves and a high quality mask is almost mandatory. For extended work a mask with a outside at supply and oil less compressor is the best choice. Googles get so dirty you can't see also.
07-30-2014, 08:05 AM
Trailer: 1974 Scamp 13'
Malvern, Ohio
I just cut an 18x18 inch hole in my scamp. What I used was a jigsaw with a carbide grit blade I picked up at harbor freight. All the big box stores have them. Clean cut with no chips and hardly any dust.
2-3/4 in. U-shank Carbide Grit Jigsaw Blades 3 Pc
07-30-2014, 08:39 AM
I had zero problems following a straight line. The control was the best of any cutting tool without a physical guide. The cut off type of tool is hard to correct if needed.
07-30-2014, 09:13 AM
North Florida
Roger, I am not sure if are thinking about some other kind of saw blade but all of the jigsaw (and reciprocating saw) blades I have ever seen are made with the teeth angled back toward the foot ("up cut" in your description). You are correct that a blade with the teeth pointed away would be a miserable outfit to try and cut something with.
08-02-2014, 03:11 PM
Trailer: Boler 13'
Thanks guys. Great suggestions!!
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
