1970 Boler renovation - Fiberglass RV
Old 04-22-2017, 11:36 AM   #1
So when asking questions it was requested​ that I post some progression pics. So here they are.Click image for larger version
Pgmopar is offline   Reply With Quote
Old 04-22-2017, 11:37 AM   #2
This is the start point
Old 04-22-2017, 11:38 AM   #3
Old 04-22-2017, 11:39 AM   #4
Everything pulled out
Old 04-22-2017, 11:40 AM   #5
Old 04-22-2017, 11:40 AM   #6
Trailer and shell separated
Old 04-22-2017, 11:42 AM   #7
at least 3 or 4 repairs to hitch point so old hitch removed.
Old 04-22-2017, 11:43 AM   #8
at least 3 or 4 repairs to hitch point so old hitch removed. End boxed in waiting for new hitch.
Attachment 105200
Old 04-22-2017, 11:44 AM   #9
ID:	105202 new hitch tacked on. Extended 18"
Old 04-22-2017, 11:45 AM   #10
Attachment 105202 new hitch tacked on. Extended 18"
ID:	105203 new stronger support for door frame and step.
Old 04-22-2017, 11:47 AM   #11
Attachment 105203 new stronger support for door frame and step.
ID:	105204 4" block installed to lift trailer. So more camp sites in northern British Columbia can be accessed.
Old 04-22-2017, 11:50 AM   #12
Attachment 105204 4" block installed to lift trailer. So more camp sites in northern British Columbia can be accessed.
ID:	105205Dual propane tanks and spare tire carrier spot installed. And battery box. The trailer was not 12v compatible. It will be now.
Old 04-22-2017, 11:52 AM   #13
Attachment 105205Dual propane tanks and spare tire carrier spot installed. And battery box. The trailer was not 12v compatible. It will be now.
ID:	105206 first box of Amazon order. 7 wire harness and variable switches ,lights and system monitoring equipment.
Old 04-25-2017, 09:30 PM   #14
Johnny M's Avatar
Deep South
before you go much further I would check the torsion axle...my 71 Ingersol Rub R Ride was wore out and I replaced it with a Dexter #9 for around $200 or so
1971 Boler 1300 - "Suite 13"
1987 Play-Mor II - "The Beach House"
Old 04-25-2017, 09:33 PM   #15
Ty. Torsion appears still fine. At least it is light to Jack up if I need to grind off and replace....Lol
Old 04-26-2017, 06:15 AM   #16
Johnny M's Avatar
Deep South
Mine did too until I noticed my brand new tires had severe tread wear on the inside shoulder of both tires, up close you couldn't tell but when I looked at them from a distance in a large parking lot you could see the tires leaning in towards each other. If it is the original axle you will probably find a small plate on the axle tubing close to one side that reads "Ingersol Rub R Ride". Mine had paint on it but cleaned off you could see the embossing of the letters. If you find that I would highly recommend replacing it, but it is possible yours has been replaced since 1970 (but not likely).
Old 04-26-2017, 08:32 AM   #17
I hope it is ok. I am doing this rebuild for one camping trip per year. But I will definitely look for odd wear on the tires. Thanks for the heads up. I will also look for what that plate says. Didn't even think of looking at it. Good info.
Old 05-07-2017, 01:02 PM   #18
Shell sanded and area around old vent sanded down to cover up. All cracks sanded away to start repairs. Now to move outside degrease and wash. Then repairs start this week.
Old 05-07-2017, 01:02 PM   #19
ID:	105761Click image for larger version
ID:	105762Click image for larger version
Old 05-17-2017, 11:58 AM   #20
First wash
Washed the shell down from sanding. I missed a few spots.
boler
1974 Boler renovation started today Tom in Meigs Ohio Care and Feeding of Molded Fiberglass Trailers 0 10-25-2013 11:11 PM
1971 Boler Custom renovation—Let the fun begin! Robert Johans Modifications, Alterations and Updates 80 10-15-2013 09:26 PM
1970 Campster Renovation Chris McGurk Modifications, Alterations and Updates 4 06-03-2012 03:24 AM
1975 boler renovation. kendasmike Problem Solving | Owners Helping Owners 0 04-26-2012 07:03 PM
1972 Boler For Sale Complete Renovation Done - SOLD Dana Fraser Classified Archives 2 07-27-2009 08:27 PM
