Portable Waste Tank for 'EGGCAMPER' - Fiberglass RV
Old 06-02-2018, 10:23 AM   #1
Trailer: eggcamper 2006#37
Hi All,
I was hoping someone out there could help me with which waste caddy or portable waste tank to go with for extended non hook up stays.
I had one all picked out until I read it was wise to consider that 'low trailers may need a low clearance waste tank' The Eggcamper meet the poop tube at 7" off the ground and most caddys are 11.5 inches high so I think that would be a problem.
I would like to get gray and black at the same time making it a 32 gallon caddy tank for eggcampers black being 8 Gallons and Grey being 24.
Any wisdom and experience in this subject greatly apprieciated thank you and happy egging!
abwegg is offline   Reply With Quote
Old 06-02-2018, 10:26 AM   #2
Glenn Baglo's Avatar
A 32 gallon caddy will weigh more than 250 lbs.
Old 06-02-2018, 05:14 PM   #3
Thank you yes I am aware of the weight. I was going to get a 4 wheel Baker (see link below) Do you mean it is common place to take Black Water first to dump and then come back for the Grey Water to flush the portable waste tank? Please clarify what you mean other than if you mean its a weight issue, this hooks right up to your trailer hitch and off ya go. I need to know what people use for Eggcampers staying a long time or use their campers for when company comes over and they use the toilets.
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Old 06-02-2018, 07:09 PM   #4
I just drag the black and grey tanks to the dump, as situated, in the trailer. No transfer, easy peasy. Get the fresh water filled at the same time and stop at a beer store.
Old 06-02-2018, 09:43 PM   #5
It would be a bit of a hassle, but you could nudge the camper up on blocks when you want to drain the tanks into a waste caddy. There are the plastic ones you can purchase that would be light to carry along. I made these from scrap pieces of 2" x 8" lumber to raise the front end our low-slung Prius when I need to slide underneath the front end to change the oil.
War Eagle is offline   Reply With Quote
Old 06-03-2018, 06:38 PM   #6
Andrew, While a bit costly, it looks like a macerator would fill your need. You could even leave the portable waste tank in the bed of your pickup (if you tow with a pickup, that is) for easy hauling and draining and let the macerator pump the liquefied waste up into it. The following link includes a good discussion at the bottom with several suggestions for supplying 12V DC power to run the macerator. RV Macerators And How They Make Dumping Waste Easier
Just a thought....
Old 06-04-2018, 11:25 AM   #7
Trailer: EggCamper
Montana
I just "milk" the flexible sewage hose when I'm done draining my trailer tank. I connect the hose between my trailer and the external tank and let the hose rest on the ground. When I open the waste water valve, water fills the hose and overflows into the transfer tank. When I'm done draining my trailer tank (and before the external tank is full!!!!) I close the valve to stop any more waste water from entering the hose. Then I lift the hose where it connects to my trailer, bending it higher than the trailer sewer pipe. I move the high point of the hose along its length until I reach the transfer tank. I'm basically manipulating the hose to create a wave shape in the hose, with the peak of the wave moving toward the transfer tank. Perform this motion at least three times, or until the hose is empty. Also, make sure you have enough room in the tank to accept the water in the hose.
I'm not sure I'm describing this very well (or maybe I've over explained), but this is how I drain the tanks for my Eggcamper. I've encountered many campgrounds where the sewage connection is higher than my trailer's sewage outlet. Hope this helps.
Eric in MT is offline   Reply With Quote
Old 06-04-2018, 11:56 AM   #8
Steve L.'s Avatar
Whoa! It's been awhile since I've been able to trot out the M.O.A.T. (The mother of all totes).
I had decided to upgrade the wheels. Relatively easy job. Not ready for highway speeds but still easier to move about and much quieter. I considered a biohazard sticker but some people have no sense of humor...
To be honest, I use the 5 gallon tote (no wheels) to decant off a bit of grey water more than this tank (15 gal.). If grey water only, I have an excess bilge pump to move water uphill.
Both of which are Barker tanks which I've been satisfied with so far. The low profile tanks weren't available when I purchased.
Without adult supervision...
Quando omni flunkus, moritati.
Also,
I'm a man, but I can change, if I have to, I guess.
Steve L. is offline   Reply With Quote
Old 06-04-2018, 12:04 PM   #9
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Steve, the guy whose picture is on the side must have had one HOT burrito!!!
Old 06-04-2018, 12:18 PM   #10
Steve L.'s Avatar
I'm like most 4 year olds, once I get started on potty humor, I'm hard to stop.
Also,
eggcamper
Portable Waste Units DeanCHS1980 Plumbing | Systems and Fixtures 25 08-09-2016 09:24 PM
portable waste water storage swenny Problem Solving | Owners Helping Owners 1 05-25-2012 09:29 AM
Moving Black Waste Tank Don A Plumbing | Systems and Fixtures 2 10-25-2010 05:12 PM
1978 Boler Waste Tank Leaks Errol Holbrooke Problem Solving | Owners Helping Owners 0 08-29-2010 03:02 PM
Portable Waste Disposal Tanks Steve Dunkel General Chat 4 11-26-2009 11:39 AM
