Oxygen Propane System - Fiberglass RV
Old 08-02-2018, 08:34 AM   #1
Trailer: Bigfoot B 17 deluxe
Question Oxygen Propane System
The Propane line which I discovered in the storage area next to the door was disconnected under the trailer .... this was peculiar .. I investigated to find the rubber line was cracked due to the bend needed to go through the floor ..... I removed the rubber line and replaced it connecting all the components ..... then the FUN began. To make a long story short it would seem that this line was intended to feed a stove or ?? (like a 2 burner coleman) for outside use .... BUT all of the propane after the regulator is low pressure ...... Coleman stoves and propane lights must have high pressure propane to operate SO seems that this line is of no use ............ on my trailer it has been removed ....... any thoughts ????????
Corbett Road is offline   Reply With Quote
Old 08-02-2018, 10:02 AM   #2
BatDude's Avatar
Trailer: Escape
Hmmm
Hope you find an answer to your line question.
Your topic triggered a memory of when we lived in Belize and the new huge hospital in BZE CTY was completed. Unfortunately one of the construction folks (less than well educated) hooked up the butane tanks for that water heater systems to the oxygen lines! So all rooms that would have had oxygen for emergencies now were butane filled.
They never did fix that and once contaminated it was just never used.
Bat Dude
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 08-02-2018, 10:44 AM   #3
Trailer: '15 17' LD Casita and '17 Tahoe LT
Sort of off topic, but we had a new home built and when they turned on the utilities, the water line was hooked to the gas line.
dmad1 is offline   Reply With Quote
Old 08-02-2018, 10:49 AM   #4
Trailer: 2017 Escape 5.0 TA
Connecticut
🤔You had a rubber line feeding propane inside your camper? I’m pretty sure that that’s not legal in the USA and probably not in 🇨🇦. I have an optional propane hookup outside on my Escape. It is a copper line with a shutoff at the end. It is low pressure and I use it for my Q1000 grill (removed the regulator). Maybe someone tried this and used rubber instead of copper. Not a good idea.
Cliff Hotchkiss is offline   Reply With Quote
Old 08-02-2018, 10:51 AM   #5
Connecticut
😱 Could have been worse, the other way around.
Old 08-02-2018, 11:11 AM   #6
Ian-Vicki's Avatar
Trailer: 17 ft Burro Widebody / 2007 Ford Ranger
When we brought our Burro home to Canada from the US, in order to have it registered here, we had to replace all the existing rubber propane lines with copper. Maybe time to talk to an RV repair place.
Ian-Vicki is offline   Reply With Quote
Old 08-02-2018, 01:07 PM   #7
Trailer: Scamp 13
The line may have been used for a catalytic heater?
Old 08-02-2018, 05:22 PM   #8
Connecticut
Your Burro came with rubber propane lines from the factory?
Old 08-05-2018, 07:08 PM   #9
Trailer: 2002 Bonair Oxygen
That line under the bench is for an auxiliary propane heater. Once I am home, I’ll post some photos.
As previously said, the line through the floor must be a solid line, unlike the flexible hose that came with the unit originally from BonAir. We had ours changed by a certified propane technician.
Kirby C is offline   Reply With Quote
Old 08-05-2018, 07:55 PM   #10
... To make a long story short it would seem that this line was intended to feed a stove or ?? (like a 2 burner coleman) for outside use .... BUT all of the propane after the regulator is low pressure ...... Coleman stoves and propane lights must have high pressure propane to operate SO seems that this line is of no use ............ on my trailer it has been removed ....... any thoughts ????????
I have seen a few campers where the low pressure stove inside the camper was removable and there was a bracket on the outside to mount the stove, along with a quick connect for the propane line (which is also low pressure). The same line could be used for an aux heater such as a Wave.
Old 04-22-2019, 09:05 AM   #11
Steve Hammel's Avatar
Trailer: Trillium 4500
The line is definitely used for a catalytic heater.
Are you still planning on attending the Spring NOG? We will also be there with our Oxygen. Unfortunately when we booked we had to book across the street.
Steve Hammel is offline   Reply With Quote
Old 04-22-2019, 10:05 AM   #12
NOG
Hi Steve ...... Yes we will attend ........ We will be over in M section .. My info is in the car BUT I think our sight is M 36 ........ also on the right hand side of the road ................ Look forward to seeing the various units .. let's think sunshine !!!!!!!
Old 04-22-2019, 10:33 AM   #13
Cool, this will be the first rally I've attended where there was more than one Oxygen in attendance. Ours is bone stock other than the two tone silver paint but I have several projects I'm planning on.
Old 04-22-2019, 04:11 PM   #14
Oxygen
Look forward to meeting you and your Oxygen ...... We've named ours Eggbert , which does have a bit of an Easter feel ..... safe journey .. john/eve
Old 04-22-2019, 04:41 PM   #15
I believe we're in C63.
oxygen, propane
Elect water heater propane or solar on Oxygen 2002 Leobon Electrical | Charging, Systems, Solar and Generators 11 04-07-2017 11:14 AM
Upgrading propane system beardrum Modifications, Alterations and Updates 11 08-06-2013 02:44 PM
Getting in touch with Oxygen owners Yves Pelchat General Chat 5 03-25-2012 11:58 AM
75 SurfSide goes for propane system check Scott S. Modifications, Alterations and Updates 5 06-26-2008 07:12 AM
