1978+/-Amerigo insearch of R+L Thread Wheel Bolts - Fiberglass RV
Old 04-10-2019, 01:58 PM   #1
Trailer: Amerigo F-16 1978?
New Hampshire
Hello All,
I would like to replace my wheel bolts on my hubs.
I sent my camper off to have the frame and brakes worked on and the company butchered my Left hand thread wheel bolts.
You know the ones marked with a big L on top!
Even though I warned them of the circumstances.
Hex head 7/8 approx .800
Cone seat
1" Long shaft
1/2" Diameter
13 Threads per Inch
30 Degree Pitch
I can have the hex head machined down to the next wrench size, but was hoping to replace with new or nice used.
Thank you in Advance.
Jonathan
JonnyX151 is offline   Reply With Quote
Old 04-10-2019, 07:25 PM   #2
SteveV's Avatar
Trailer: Amerigo FG-16
Jonathan, I have found the correct right hand wheel bolts at Northern Tool.
Although both of my wheels have RH threads it is possible you have a lefty on yours.
Check with your local NT, they may have the LH available thru special order?
SteveV is offline   Reply With Quote
Old 04-11-2019, 10:54 AM   #3
Any reliable brake shop should have them.
If the bolts were "buggered up" you should have them run a thread chaser (tap) in the bolt holes.
Old 04-11-2019, 01:53 PM   #4
New Hampshire
Hello Steve,
Thank you very much for that quick find I will check those out for sure!
I appreciate the picture that is a huge help.
Jonathan
Old 04-11-2019, 01:55 PM   #5
New Hampshire
Hello Wayne,
Thank you for the tip I will ask around most places if it has not sold in over a year it is no longer stocked. Maybe they will take the time to look it up.
Thank you
Jonathan
amerigo
